Need help Question about sway bar
I have a 1977 short box it has the holes in the A frame for the bushing but the frame has one hole on each side but no bracket where the bushing go what's up.
![]() Join Date: Feb 2016
Re: Need help Question about sway bar
Trucks that weren't equipped with a swaybar from the factory didn't have the frame brackets. But, all trucks had holes in the control arms for one regardless.
So can you put the bracket on ?
Yes, since your truck is lowered I would recommend you get the shorter brackets that are made for lowered trucks.
80 C10 SWB Step Side - 350 w/ vortec heads, TH350, 12-bolt 3.73 |
FWIW: Here is a picture of my 77 Chevy Sport with the factory installed front
sway bar. (F59) Larry ![]() |
To my knowledge, there are only two manufacturers of the shorter brackets, CPP and Early Classic Enterprises.
I have used both. The ECE ones are a slight bit better value as they include mounting hardware and the CPP ones require you to supply it. Virtually the same cost for the two different brands. The ones in the picture above are CPP brand which I bought from Summit as I could get free shipping on my order and it wound up saving me about ten bucks in the end since I didn't have to place a seperate order for the ECE ones. The bolts, nuts, and washers I had on hand in my bolt bin so the lack of hardware with the CPP parts were a non issue compared to saving shipping charges on the ECE ones. |
#9 | |
The same brackets fit from 63-87. For some reason the vendors haven't picked up on that.
This is the bracket in the picture I posted above. http://www.summitracing.com/parts/cl...b/applications |
#11 | |
#12 | |
I'll snag some better pics for you tomorrow. They should clear up any questions. That pic I posted sucks.
#15 |
#16 | |
#17 |
I used the CPP sway bar when I installed their lower arms. I do have an extra set of lowered sway bar brackets that I bought earlier. The bar came with a set too. Extras are yours if you want them, just pick up the shipping and add your own bolts.
#18 |
Thanks you but I just ordered some from summit thanks
| Bookmarks |
