V8 Motor mounts
Switching out the straight 6 for a V8 small block.
What are the best motor mounts to use? Anything else that I should be aware of as far as the swap? Thanks |
Re: V8 Motor mounts
I just installed a 327 in place of the original 250 6. I used the same mounts.
1966 Chevy C10 2WD SB |
60-66 Nut
Re: V8 Motor mounts
There is no need to change anything unless your I6 was a 292. If your I6 was a 230/250, the small block just drops in the exact same place with the same engine mounts. That is how/where GM originally installed them.
Re: V8 Motor mounts
IF you are replacing with NEW mounts you might consider poly mounts they last a life time
Re: V8 Motor mounts
