Old 04-17-2016, 02:10 AM   #1
Softpatch
Softpatch's Avatar
59 viking lower fender reconstruct
started this thread to show pictures of the lower pass side fender reconstruct
back in the day just drill a hole ad a long bolt and fender washer call it good
....Fast foward 38 years with The help from the people here the internet
almost all parts for these truck available thought I could do better
Before
Not fnished just yet why the vicegrips
Originally Posted by _Ogre View Post
part number 6 and 9 from lmc truck should fit your fender
you'll only use a sliver of the fender panel but the fender brace will be the same
with some creative hammering you could introduce the curve if you need to
your viking uses the same 31-38 cab and thus the back portion of the fend should fit too
Originally Posted by Softpatch View Post
yes and no...
I understand buy the lower fender piece (outer skin) and hammer and stretch
it to the shape
I don't have those skills... I've tried it doesn't come easy
the magic is were the inner fender skin that runs up the edge of inside the fender & connect to the lower corner of cab bracket that inner piece is gone
either have to fab it a find a good used fender to butcher
Stdby I got a pic......Sp
Find a Viking fender because the wave in the viking fender
(non Apache) to flat .... Not sure..?
this is the piece (in red ) I don't think is available.?
it bolt here to the cab
AFTER
My Spelling is Not Incorrect...It's 'Creative'
1966 C-20 .....Swap 91 G-30(5.7 FI)/4L80E
http://67-72chevytrucks.com/vboard/s...d.php?t=789617
59 Viking Revival .. http://67-72chevytrucks.com/vboard/s...d.php?t=632341
Softpatch is offline   Reply With Quote
Old 04-17-2016, 11:51 AM   #2
dsraven
Re: 59 viking lower fender reconstruct
the front fender lower inner brace is available for the pick ups for about $30. the cabs are the same, so the profile would be the same where the fender and the cab meet. maybe you could make one of those brackets work on the back side of your fender so you could support the fender to the cab mount area. then fab up or buy a lower rear fender patch for a pick up and use what you need to fit your fatty fenders.
Old 04-18-2016, 01:53 PM   #3
_Ogre
_Ogre's Avatar
the fender brace was one of the part numbers i listed from the lmc link
you doing a bang up job on the cab restoration
shop air compressor timer
Old 04-18-2016, 11:08 PM   #4
Softpatch
Softpatch's Avatar
just want to get it by inspection & start the clock on the paper
Holy Smoky #9
that is very cool thanks man
Old 04-18-2016, 11:18 PM   #5
Softpatch
Softpatch's Avatar
The hood needs alot of love to bring it back
I bought a spare hood that was solid but needs alot of work last yr so I could keep going
little primer some semi black to stop the rust
Waiting for some high dollar wipers
Old 04-19-2016, 02:08 PM   #6
_Ogre
_Ogre's Avatar
use rain-x
the only arms for our trucks are total pos
Old 04-19-2016, 05:11 PM   #7
Softpatch
Softpatch's Avatar
use rain-x
it is good stuff unless you have a windshield that has a lot of pitting
Last time took a car in for an inspection...
the Trooper wanted to see the wipers working ...
Flashers, all ext lights working hi-lo beams the works
