Closed Thread
Old 04-18-2016, 11:34 PM   #2226
HackJob65
Re: What did you do to your truck today part III
Got a little closer to wrapping up front suspension and disc swap CPP drop spindles and 3" drop springs Summit 6lug rotors
HackJob65 is offline
Old 04-19-2016, 01:32 PM   #2227
65chevysub
65chevysub's Avatar
Had to replace my radiator. A friend of mine had one laying around. Only differences are;
Drain is on opposite side and the overflow nipple points towards right side, so will have to have it turned around for overflow bottle. Has anyone used a radiator from Classic Industries? If so does if look original and how is the fit?
65chevysub is offline
Old 04-21-2016, 12:14 AM   #2228
Samz
Put wide whitewalls on her today. Getting ready to paint her. Just picked her up a few days ago. Also waiting on my oak wood bed kit to show up. Got several other things to do to her.
1960 C10, shortbed, step side, big back window, 350, Turbo 400
Samz is offline
Old 04-21-2016, 03:02 PM   #2229
sharkskinman
Got great deal on some stuff
http://67-72chevytrucks.com/vboard/s...d.php?t=704301
-Standard rebuilt 72' 250..0 miles!
-Muncie M20 wide? 4 speed w/ mounts for floor shifter?
-Saginaw 3 speed w/floor shifter
Engine and both trans' are clean and rebuilt/resealed
Currently SM318 in the truck
Thinking about the 4 spd (as it also has syncro 1st?)
But need shorter drive shaft(does it has to be made or is there a direct swap out?)
Hopefully engine will go in and be broken in this coming Wed!
So much rain on my days off lately
sharkskinman is offline
Old 04-22-2016, 07:18 PM   #2230
Chevy Fleetside
Chevy Fleetside's Avatar
Finally hooked up my fuel fill. Now we will see if it works good enough to really use. I tacked it in for now.
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline
Old 04-22-2016, 07:52 PM   #2231
robber grin
Got my Grant adapter and Moon wheel installed then found the passenger side vent shade that was buried and got it installed too
robber grin is offline
Old 04-23-2016, 04:10 AM   #2232
Grizz1963
Grizz1963's Avatar
I absolutely love that.
It's exactly what I have planned for mine, not in the corner at the moment.
Do you have any pics of the process and underside please?
MY BUILD LINK: http://67-72chevytrucks.com/vboard/s...585901]Redneck Express - 1966 C10 Short Fleetside
MY USA ROADTRIPS http://forum.retro-rides.org/thread/...2018-humdinger
IF YOU CAN'T FIX IT WITH A HAMMER, YOU'VE GOT AN ELECTRICAL PROBLEM MATE.
Grizz1963 is offline
Old 04-23-2016, 08:48 AM   #2233
Backpayne
I dumped 4 quarts of oil into the engine before I realized the drain plug was not in. I'm an idiot.
Backpayne is offline
Old 04-23-2016, 10:36 AM   #2234
Chevy Fleetside
It is just molded rubber gas hose. I got it at http://www.fillernecksupply.com/ther...FUiPfgod5H4IuQ It works ok. The tank won't fill all the way up but pretty close.
Old 04-23-2016, 11:31 AM   #2235
been there, done that...got the ID-10-T t-shirt
Palf70Step is offline
Old 04-23-2016, 05:17 PM   #2236
Slow Build
Slow Build's Avatar
No. You were just flushing out the old oil. Good job.
Current Ride: 1964 C-10 Short Fleetside
Daily Driver: 2005 GMC crew cab short fleetside /2001 Chevy Tahoe
Past GM Trucks:
1959 GMC short stepside
1968 GMC short stepside-4x4
1973 Chevy short stepside
1989 Chevy short fleetside-reg cab
1993 Chevy short fleetside-Xcab
2002 Chevy short fleetside-Xcab
Save the dinosaurs, use synthetic oil.
Slow Build is offline
Old 04-23-2016, 06:23 PM   #2237
Backpayne
Actually, it did need to be flushed. The needle valve in the carb got stuck open and dumped gas in the block.
Old 04-23-2016, 07:51 PM   #2238
OldChevy61
OldChevy61's Avatar
It has been a long day. Got the motor and trans installed and bolted down then moved on to the cab. Beginning to look like a truck again.
OldChevy61 is offline
Old 04-23-2016, 08:48 PM   #2239
jbgroby
jbgroby's Avatar
Getting the end buttoned up.
jbgroby is offline
Old 04-23-2016, 10:13 PM   #2240
my04
my04's Avatar
Cool truck, I've never seen a bell housing with the clutch fork on the passenger side though, I'm confused
my04 is offline
Old 04-23-2016, 10:19 PM   #2241
my04
my04's Avatar
Installed fresh engine and got it running the past few days....Name:  0418161320.jpg
my04 is offline
Old 04-23-2016, 10:38 PM   #2242
sodly
sodly's Avatar
Originally Posted by my04 View Post
Installed fresh engine and got it running the past few days....Attachment 1525786
Attachment 1525787
Attachment 1525788
Attachment 1525789
Attachment 1525790
Looks nice. FYI, there should only be one 327 decal on the passenger side valve cover. They never put them on the drivers side.
WANTED:
* 60-66 Chevy and GMC FACTORY PHOTOGRAPHY (scans) of pickups and carryalls.
Custom Camper Club-- Own a 65-66 Custom Camper? Join us at: http://67-72chevytrucks.com/vboard/g...hp?groupid=117
sodly is offline
Old 04-24-2016, 07:26 AM   #2243
jbgroby
jbgroby's Avatar
My original 305 V-6 had the clutch fork on the passenger side.
jbgroby is offline
Old 04-24-2016, 07:31 AM   #2244
OldChevy61
OldChevy61's Avatar
Factory 62 hydraulic clutch.
Old 04-24-2016, 01:24 PM   #2245
my04
my04's Avatar
I'll be darned, I had never seen that before, thanks for the info.
my04 is offline
Old 04-24-2016, 04:05 PM   #2246
jbgroby
jbgroby's Avatar
Got the tailgate on. i will remount the bumper this week, once I get through connecting the tail light wiring. The GMCis painted the correct factor reflective silver, is was so the person behind you knew what hit'em when they rearend you .
jbgroby is offline
Old 04-24-2016, 07:11 PM   #2247
64shortbed
64shortbed's Avatar
Put my new seat cover from classic industries on today!
64shortbed is offline
Old 04-24-2016, 07:53 PM   #2248
earl84
Dang, jgroby and OldChevy61, that is some nice looking paint. OldChevy61, that's my favorite color scheme, love it.
earl84 is offline
Old 04-24-2016, 08:58 PM   #2249
DPowers
One foot in front of the other
DPowers's Avatar
Pulled it out from it's winter nap and washed it.
DPowers is offline
Old 04-24-2016, 10:26 PM   #2250
60chevyjim
60chevyjim's Avatar
Dwaye your truck looks great !!
60chevyjim is offline
Closed Thread
