Where is the oil leak coming from?
Ok, I had my truck parked in the garage for about 3 weeks. Yesterday I noticed a large and almost the size of the truck OIL spill. The garage is level and can't figure where it came from. Any ideas where to start? the drain plug?
thanks in advance.. |
![]() Join Date: Mar 2003
Re: Where is the oil leak coming from?
Assuming engine oil, the only place just sitting, has to be the drain plug gasket.
Keep in mind that a couple ozs on concrete spreads out and looks like BP has spilled in your garage. A drop or two can get really big on concrete. The gasket on the drain plugs are prone to cracking and leakage making messes where ever you go.
20' Daredevil (Ret)
![]() Join Date: May 2003
Need to determine if it's engine oil, or transmission fluid (auto or manual?) or maybe something else like coolant or even brake fluid. Has any work been done on the truck recently?
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay |
lay down on the garage floor and put your head directly in the middle of the oil puddle and look up that's a good way to start loookin for the leak
A little oil will go a long ways on the floor but if it's under all four tires, that's a good leak. Is the engine low on oil? If not, I'd suspect trans tail shaft...
'77 K30 3+3 - "The Crummy" http://67-72chevytrucks.com/vboard/s...d.php?t=640134 '67 C10 L/SWB - Soon to be daily driver! http://67-72chevytrucks.com/vboard/s...d.php?t=471776 ![]() |
![]() Join Date: May 2012
Stick your finger in it then smell it. Then you'll know, trans or engine. Trans and engine smell significantly different. If have a manual trans, else you can just look at it.
White K20 |
oil filter loose?
push it foreward about 10 feet and watch for a fresh leak on the floor..
Thanks, Joe.. 1969 C/10, 348 C.I., 3X2 bbl. V8, 2004r , LWB. |
Go Pack Go!
Start by crawling under the truck and look.
