Old 04-19-2016, 12:44 PM   #1
Guy67UK
Guy67UK's Avatar
Anybody identify these rotors
Firstly if this is in the wrong place please can an Op move it.
I have recently bought a 67 C10 Stepside and shipped it in from Texas to the UK, well it has got a few issues I didnt know about most of which I have now sorted (wiring etc) and some I am going to leave for a year (paint). To get the truck registered over here It needs to be road worthy. Well the brakes are shot. The pedal was going to the floor with very little effort thankfully the emergency brake worked (just). I found the rear brakes had siezed adjusters on both side now sorted. The whole system was bled but no pedal, the master cylinder was changed as was the booster no pedal. The truck had been converted to power discs and I read on here that power brakes needed to have another hole lower down on the brake pedal that was drilled and I got a fantastic pedal thought my troubles were over untill I went down the road and the same result..... no brakes. I now pulled off the front wheels and check out the calipers and rotors and found the caliper at the far end of its travel on the sliders as the rotor nis well below its min thickness and all the wear is on the inside edge of the disc..
I dont have a pepboys or autozone down the road to go and identify what the discs are off and will have to order them in and dont want to get the wrong parts over. So can anyone help ID these rotors. they have a 4.75pcd and are on a Western Chassis dropped spindle
I hope someone can point me in the right direction with this
Guy
Guy67UK is offline   Reply With Quote
Old 04-19-2016, 03:40 PM   #2
68bowtie
68bowtie's Avatar
Re: Anybody identify these rotors
check the bolt pattern, rotor diameter and thickness, and the casting numbers. that should help figure it out.
Old 04-19-2016, 03:44 PM   #3
67ChevyRedneck
67ChevyRedneck's Avatar
In your 2nd pic you can just see a part number clipped on in the lower left corner. "Google" that number.
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 04-19-2016, 05:10 PM   #4
Guy67UK
Guy67UK's Avatar
My mistake after remeasuring it turns out that the Pod is 5"
After googling the cast number I am still no closer for a specific vehicle fitment
Old 04-19-2016, 05:52 PM   #5
68bowtie
68bowtie's Avatar
i'm not sure what "pod" or "pcd" is, but if you post the items i mentioned earlier that will help us know what you have.
Old 04-20-2016, 12:07 AM   #6
Guy67UK
Guy67UK's Avatar
the pcd refers to the bolt pattern and that is 5 on 5
cast number is 3963996
Diameter of disc appears to be 11 13/16 (11.8")
the min thicknes of the rotor is 1.125" so at a guess I would say it was 1.25" originally
Thanks for the help 68bowtie
Old 04-20-2016, 03:30 PM   #7
67c10rustbuket
67c10rustbuket's Avatar
1971-1986 Chevrolet c-10 trucks. Standard equipment on earlier years while later years 1980?+- had two options 1.00 thk rotor or 1.25 thk. Of course you have the thicker or sometimes called HD brakes. Just order parts for a 71 through 79 it's the same brakes.
Dan <---(my name)
67 SWB C10 project "GEORGIA"-59 Brookwood 2dr wag...Next project-03 Tahoe 4x4 5.3 family ride-07 Hondur Accord, commuter car
67c10rustbuket is offline   Reply With Quote
Old 04-20-2016, 03:52 PM   #8
michael bustamante
michael bustamante's Avatar
i was just going to say early 70`s c10
1967custom
michael bustamante is offline   Reply With Quote
Old 04-20-2016, 04:36 PM   #9
ga-stepside
ga-stepside's Avatar
Good information. I have been trying to find out what I have too. That is the same setup on my truck. Casting on the rotors is 3963996 and they are 1.20" thick. BTW the calipers I have are casting caliper GM 5474177.
1967 C10 Step side
1970 AMX 390
1977 Datsun 280Z highly modified with '95 LT1 power
ga-stepside is offline   Reply With Quote
Old 04-20-2016, 04:47 PM   #10
ga-stepside
Question about the rotors. I got on Rockauto.com and ACDelco has two options. A 4.65" height and 4.95" height. I measured mine from the back of the rotor to the outside of the hub and got 4.95". Am I measuring that correctly?
1967 C10 Step side
1970 AMX 390
