Old 04-19-2016, 01:43 PM   #1
rads42
Roll bar mounting
After years of trying to find a roll bar for my blazer I finally got one. Obviously after cleaning it up I'll be installing it. It's the type that the rear down tubes mount right behind the wheel well. In fact the very end of the mounting plate is turned up slightly to match the angle of the wheel well. I plan to use the mounting plates as templates to drill the holes in the bed and a backing plate. One thing I was unsure of though is how to trim the carpet around the newly installed bar in a way that looks neat? My truck is very original and nice and I don't want it to look like a hack job with fraying carpet all around. Other than having the edges bound (p.i.a.) does anyone have any ideas or know what a dealer install with this type of set up looked like? Thanks in advance for any suggestions.
rads42 is offline   Reply With Quote
Old 04-19-2016, 03:07 PM   #2
6768chevylover
6768chevylover's Avatar
Re: Roll bar mounting
My blazer didnt have carpet in it when I bought it, it had the vinyl mat. Its got carpet in it now. When I took the roll bat out to do some work on it, the mat just had holes in it to match the bolt pattern of the bar mount. I would think they did the same for the carpet..
6768chevylover is offline   Reply With Quote
Old 04-20-2016, 10:46 AM   #3
rads42
Huh...I hadn't considered going right over the carpet. Can anyone confirm this is the way to go? Anyone with a picture of how theirs mounts would be really appreciated.
Old 04-20-2016, 12:10 PM   #4
FORCE72
FORCE72's Avatar
I installed mine right over the carpet. Looks good and know worries of the carpet fraying. Try to get a pic for you.
FORCE72 is offline   Reply With Quote
Old 04-20-2016, 01:45 PM   #5
rads42
A picture would be much appreciated if you can find the time!
Old 04-20-2016, 02:23 PM   #6
JJH Jimmy
JJH Jimmy's Avatar
I put mine in on top of the carpet. Just use a cheapo soldering iron to make the holes so the carpet does not fray.
1972 GMC Jimmy 4x4 LS Swap
1985 Chevy K20
1994 GMC Yukon
2021 GMC 2500HD Duramax AT4
My "It's a Jimmy Thing" Build
http://67-72chevytrucks.com/vboard/s...d.php?t=583528
Budget Build 1985 K20
http://67-72chevytrucks.com/vboard/s...d.php?t=801565
JJH Jimmy is offline   Reply With Quote
Old 04-21-2016, 08:37 PM   #7
warbucket
warbucket's Avatar
I'm on top too.
72 CST 4x4 Blazer, 1 ton
70 SS Chevelle, L78, 396
Everytime someone calls your Blazer a Bronco, God kills a kitten.
warbucket is offline   Reply With Quote
Old 04-21-2016, 10:10 PM   #8
tjsblazer
tjsblazer's Avatar
Yours sounds like maybe a Smitty built by your description of how it mounts behind the wheel wells. I like that style but haven't found one yet. May just have to get one made up.
Jeff.
'72 Blazer K5
"Camshaft opinions are like belly buttons; everyone has one and no two are alike"
My Blazer Build:
http://67-72chevytrucks.com/vboard/s...d.php?t=626752
My Engine Build:
http://67-72chevytrucks.com/vboard/s...d.php?t=637336
tjsblazer is offline   Reply With Quote
Old 05-06-2016, 03:01 PM   #9
rads42
I just had it sandblasted and I primed it. Hopefully this weekend I'll get some paint on it. I was going to powder coat it but it's probably going to be covered anyway so I figured I'd save some money and just spray it. When its installed I'll post some pictures. Thanks to those who replied and posted pics, that was a big help.
Old 05-06-2016, 04:55 PM   #10
GMC-YA68
GMC-YA68's Avatar
warbucket - I like the front cage on your rig. I want one now.
-Keegan-
'72 Jimmy 4x4 - 5.3/4L65E/NP205 swap
http://67-72chevytrucks.com/vboard/s...d.php?t=663780
GMC-YA68 is offline   Reply With Quote
Old 05-07-2016, 01:02 PM   #11
warbucket
warbucket's Avatar
Thank you, I scored it on Craigslist for $200.00.
