![]() Join Date: Nov 2012
Re: Tachometer Hookup Help - New Cluster!
Where did you get the tach filter? I need one of those before I hook up my tach.
FRANKENTRUCK 1981 Chevrolet C10 Shortbed Stepside GRANDTRUCK 1968 Chevrolet C10 Stepside Longbed http://67-72chevytrucks.com/vboard/s...d.php?t=584617 PROJECT JIGSAW 1967 GMC C3500 GREAT WHITE 1986 Blazer M1009 454 engine w/700R4 transmission gas conversion |
#2 | |
![]() Join Date: Jun 2014
http://www.classicparts.com/1947-72-.../#.VxoUPjArLcs
1972 Chevrolet C20 Cheyenne Custom Camper LWB - 350 / 330 HP GM Crate - TH350 / Mild Shift Kit - Dark Blue / Medium Blue - Paint Code 559 |
For the new wires I will be adding to the cluster plug (#1 and #12) I know I can use the old blue wire(s) bow terminal (blue wire = old oil sending unit wire) but will there be another un-used wire in the cluster plug that I can steal the terminal from for the other added wire??
I'm talking about these terminals...
Am I correct that when transferring from idiot lights to cluster I will no longer need to use the dark blue wire (oil sending unit) and the brown wire (generator) ?
I'm hoping so, because I need 2 bow type terminals for the new wires I have to add for # 1 and # 12. I for sure know I have 1 terminal I can use from the oil sending unit wire, but I will be one short unless I can use the dark brown wire that is marked generator. Please confirm if you have time!! You can buy these terminals from Classic Industries, but they are like $25 for a small pack with shipping and I really wanted to finish my cluster conversion tonight. Thanks! __________________
#5 | |
When it comes to re-using the terminals, I have in the past tried prying open the crimps and re-crimping them onto new wires but that is rather difficult to do without damaging the terminals. A better approach would be to simply leave a couple inches or so of wire attached to the terminals when you cut them off the dark blue & brown wires. That should give you enough length to splice them to the new wires. Also be aware that the other end of the brown wire will still be connected to the alternator / voltage regulator. So insulate the cut end with some electrical tape or heat shrink tubing so it can't touch anything under the dash and create a short circuit. |
#6 | |
Only thing left to do is to remove my old oil sending unit, and install the copper oil line in its place. Then hook it up on the gauge side as well. I replaced my old dash pad while I was in there what a PITA !! Thankfully someone had left off the middle bolts near the radio. It was an original pad. A small quality control paper fell out dated 1971 when I pulled the old pad off. Should have everything buttoned up today. Really hoping everything works as it should. Also noticed recently a burning wire smell in the engine compartment before I started this cluster conversion. The fuse able link near the battery seems to be eminating this smell. What does this mean? I don't have any special non factory accessories. Just a custom auto sound head unit but not hooked to an amp. Recently replaced my alternator with the same one that had been in there for years. What happens if my fuse able link goes out???
#7 | ||
A more likely cause would be a weak or corroded connection that is adding extra resistance to the circuit and causing the wire to heat up. So I'd recommend checking the junction block where the fusible link attaches to make sure it's free of corrosion, the ring terminal on the fusible link is in good condition and still crimped securely, and that the junction block nut is tight. The other end of the fusible link (where it attaches to the main feed wire) is usually pretty well insulated/sealed at the factory, but could still be subject to corrosion (especially since it is near the battery). Unfortunately, you'd have to cut away the factory plastic insulation cylinder to inspect that end. And it's possible that the fusible link wire itself has some internal corrosion that can't be seen due to it's insulation. If that is the case, you'd have to replace the fusible link. Use one that is the same size and close to the same length as the original. If it burns out, you will lose all battery power to the truck. If the engine happens to be running at the time, it will likely stay running off the alternator (provided the fusible link didn't blow due to a short circuit in the main feed wire). But if it's not running, you won't be able to start the engine if that fusible link is blown. Also, with the addition of the gauge cluster, the main feed wire becomes a shunt for the ammeter (battery gauge). A blown fusible link leaves the shunt open circuit which has the potential to pass a damaging amount of current through the meter movement and it's wiring (the wires you are adding to the #1 & #12 spots). That is one of the reasons it is important to have the 4 amp inline fuses in those wires. They'll blow before enough current flows to damage the meter or wiring. |
