Old 04-22-2016, 03:17 PM   #2
MountainGoat1966
Re: No left turn signal or brake light
Check the bulbs (all four corners of the truck) they can look good but still have a bad filament.
Also, clean and tighten the connectors and bolts on all the ground wires.
Sometimes, a socket will fail.
I had a socket where one of the internal contacts just disappeared and the light would not work correctly.
To this day, I still don't know where that contact strip went .......
That will fix 99.999% of the issues you have when it happens.
"Off the grid and on the seven day weekend plan"
"One person cannot know everything, but between all of us, there isn't much we don't know."
Last edited by MountainGoat1966; 04-22-2016 at 03:19 PM. Reason: Forgot the bad socket incident.
MountainGoat1966 is offline   Reply With Quote
brake light, ground, hazard, turn signal, wiring
