Closed Thread
Old 04-19-2016, 09:46 AM   #3551
matthamby
Re: What did you do to your truck today? Chapter II
OK, got some photos of my $200 replacement bed, you can follow my link here;
http://67-72chevytrucks.com/vboard/s...=1#post7565792
Thanks for looking!
matthamby is offline
Old 04-20-2016, 06:17 AM   #3552
Ft.ValloniaStreaker
Ft.ValloniaStreaker's Avatar
I'm sure not everybody is a fan of this look but I like the way the pipes turned out.
Ft.ValloniaStreaker is offline
Old 04-20-2016, 08:36 AM   #3553
Coley
Coley's Avatar
That may not be what I would necessarily do...but I like it. It shows some ingenuity and personal preference....always a good thing.
Its good to be different...nice job!
All Good
Coley
....for some men, there is experience, skill and effort....for the others...there is visa and UPS LOL
1966 Chevy 1/2 ton (Florida- Red/white)
1972 Chevy 1/2 ton (California- Blue/white)
2005 Chevy Silverado HD2500/Duramax
2000 Dodge Ram 1500
Coley is offline
Old 04-20-2016, 08:39 AM   #3554
Lanman1972
Lanman1972's Avatar
I like it, how does it Sound?
Lanman1972 is offline
Old 04-20-2016, 08:54 AM   #3555
Ft.ValloniaStreaker
Thanks Coley, and it sounds a LOT quieter than the original idea......
Old 04-20-2016, 09:16 AM   #3556
JG67
Cool old school mod.
JG67 is offline
Old 04-20-2016, 09:25 AM   #3557
JG67
The big brown truck dropped off a set of 5 lug replacement axles for my 67! Yeah buddy
JG67 is offline
Old 04-20-2016, 10:42 AM   #3558
chevy2tom
chevy2tom's Avatar
I'm thinking about doing the same thing (through the fender) off of a cutout
chevy2tom is offline
Old 04-20-2016, 10:44 AM   #3559
Ekliptix
Ekliptix's Avatar
Installed new shocks on my Dad's 71 big block.
Took my 72 out from winter hibernation and washed it.
Ekliptix is offline
Old 04-20-2016, 10:44 AM   #3560
chevy2tom
chevy2tom's Avatar
Homemade side pipes , love it
Old 04-20-2016, 12:17 PM   #3561
Ft.ValloniaStreaker
I'm running a big block, the passenger side was a breeze, the drivers, well....I thought about cutouts and tail pipes, but the cab floor is hot enough as it is.
Old 04-23-2016, 09:44 AM   #3562
Possmguts
Possmguts's Avatar
Originally Posted by gangforward View Post
3" Exhaust Install - Future SuperCharger....
Im wondering if you realized the dust storm you are going to have everywhere you go now? There was times I thought my truck was on fire when I had turn downs....
"Hey... its only time and money right? Just do it."
67 Short Bed under major construction
http://67-72chevytrucks.com/vboard/s...=651356&page=8
Possmguts is offline
Old 04-23-2016, 11:22 AM   #3563
OregonNed
OregonNed's Avatar
That's a great color of green!
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop
OregonNed is offline
Old 04-23-2016, 06:04 PM   #3564
Redline novdog
Redline novdog's Avatar
Originally Posted by Possmguts View Post
Aside from some block sanding (along with the rest of the truck) I finally wrapped this hood up... so glad that's behind me....
YA... You have probably started a 67-72 trend!!!!! 'tis the season
It builds on my intelligence when I make a mistake, Boy am I building on it!
'67 C-10,'70 Nova SS
Redline novdog is offline
Old 04-23-2016, 06:09 PM   #3565
vidman
vidman's Avatar
Started to cut my dash harness for my new gauge cluster and my first attempt at Phosphate coating. the striker plates and bolts came out great but i guess i didn,t clean the shims enough. going to try some more things on sunday
62 Willys 4wd Pickup : 72 C-10 swb 504 stroker 09 Taco 3" lift 33" tires: 90 K-5 blazer (plow truck): RIP Ross Little brother
vidman is offline
Old 04-23-2016, 07:08 PM   #3566
Possmguts
Possmguts's Avatar
lol.. thanks.. I hope the next guy has an easier time with it than I did
Old 04-23-2016, 10:25 PM   #3567
JWSmith
got the bed and cab all sanded and primer, doors hung and aligned - we are ready to lay down some paint
JWSmith is offline
Old 04-23-2016, 10:43 PM   #3568
gangforward
Hootis is as Hootis does...
gangforward's Avatar
Pure Toy - future trips to the dragstrip. Doesn't get out in the dirt much anymore. After suspension, rear end, brakes work is done, going to add a supercharger.
67 C10 LWB Fleet, 383, TH400, PS, 4BL-Holley, Headers & 3" Exhaust, 3" drop front, 4" rear springs, ECI shock relocate, Panhard Bar kit, wheels & tires
1995 Z28 Convertible - Borla, K&N, Lingenfelter Motor, C6 Wheels & Tires
1990 2500 4x4 Suburban 3" Catbac System, K&N, 2" Lift, Wheels, Tires
gangforward is offline
Old 04-23-2016, 10:54 PM   #3569
gottattooz
gottattooz's Avatar
Today on the way home from work, I recessed the grille and lowered the passenger headlight a little with the help of some friends I made in a Hyundai. Also I vented my aluminum radiator, trans cooler and engine oil cooler with the water pump pulley.
- Josh
1967 Buick Special wagon
1968 Jeep Wagoneer
1958 Chevy Panel Truck
2017 Suzuki M109R
gottattooz is offline
Old 04-23-2016, 11:03 PM   #3570
palallin
Originally Posted by palallin View Post
I broke it.
On the way home from work, I heard a hissing sound, and soon the power steering wasn't. Popped the hood to find the expected spray of fluid in the front left corner. I man-handled him home, and now I have to refill the pump to see where the leak is. I *think* its a hose and *hope-and-pray* it's not the box.
Well, I pulled the steel part of the low-pressure line off to find the hole in it caused by rubbing against the inner fender. Next step: find a replacement for the steel part of the hose or have one made.
'69 Longstep K-10: 327/SM465/T-221/Closed Knuckle Dana44/12-bolt.
palallin is offline
Old 04-23-2016, 11:05 PM   #3571
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
Sweet mod........That's a bummer. How's the frame?
I only built shelves above the garage door, for the cowl and an NOS inner grille I couldn't pass up.
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline
Old 04-23-2016, 11:21 PM   #3572
Metaldoc
Metaldoc's Avatar
- Josh
Ah man that sucks But it's just steel , it can be repaired as long as all is where ok.
Metaldoc is offline
Old 04-24-2016, 12:01 AM   #3573
firedemon
- Josh
that _ _ _ _ _ man hope you are ok and insurance covers it
firedemon is offline
Old 04-24-2016, 12:06 AM   #3574
Dimebagdavesc30
Dimebagdavesc30's Avatar
I got the bed on and the bed lights mostly working.
72 C30 283 flatbed
66 silver eagle bus
Dimebagdavesc30 is offline
Old 04-24-2016, 07:14 AM   #3575
kilrcady
- Josh
That sucks
kilrcady is offline
Closed Thread
