62 C10 neutral Safety Switch
62 C10 stock wiring
75ish GM van column what wire do I cut from the ignition switch to go to neutral safety switch? 64-66 is purple I believe but mines a 62 and there's no purple wire only pinkish |
Re: 62 C10 neutral Safety Switch
Try using a test light on the ignition switch to see which wire is energized in start position this will be your start wire . Make sure truck is in park! route this wire through safety switch and on to solenoid. D id you have any issues with neutral switch interfering with upper column mount? I had to relocate my switch further down so I could clock my column correctly
#3 | |
I relieved the side of my bracket to make room for it where it was on the tube but it's a bear to get at. thanks |
