Door lock question
Hey everyone, I have a 76 with manual door locks. I never had a key so I decided to change them. The driver side went back together fine but the passenger side was missing the little arm that goes from the back of the lock to the actually lock. I'm not sure of the name of this part is. It's the arm that's held on with the little brass clips.
Can someone tell me the name of the part or where to get one or maybe someone has a set laying around and want to let them go. Have they changed this Part in the 81-88 era trucks?
TJ 76 gmc 1500 swb patina finish Dropped 4/5, 350/4 speed 80 Chevy c10 lwb 305/350 |
Re: Door lock question
scrap/junk yard will be the best place 73-87 CHEV/GMC trucks, 73-91Blazer/Jimmy, 73-91 Suburban. Manual locks, lock rods and take extra clips to hold it when there.
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bedWas a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change. |
Actually u can still get them from classicpartsusa. It's called a door lock pawl.
| Bookmarks |
