Closed Thread
Old 04-25-2016, 10:10 AM   #2251
64shortbed
64shortbed's Avatar
Re: What did you do to your truck today part III
Pics of my seat. well that didnt work.
64shortbed is offline
Old 04-25-2016, 11:47 AM   #2252
forestb
forestb's Avatar
The painter got the grill surround, grill and bed installed. Newest pics.
forestb is offline
Old 04-25-2016, 11:48 AM   #2253
gabbin
gabbin's Avatar
My buddy helped me take the fuel door and filler tube off a 95 suburban and mount it on the back driver side were the previous owner bastardized it with a square hole, just big enough to get the cap on. We also pulled the back tailgate cross brace off and repaired where they had welded on a retainer to cover the wood. I'll get some better pics a bit later.
gabbin is offline
Old 04-25-2016, 12:14 PM   #2254
64shortbed
64shortbed's Avatar
Try this again.
Old 04-25-2016, 12:21 PM   #2255
The Rocknrod
Moderator
The Rocknrod's Avatar
Nice seat. What type of seat?
The Rocknrod is offline
Old 04-25-2016, 01:51 PM   #2256
64shortbed
64shortbed's Avatar
I got the cover from classic industries. I've been work on a guys 62 impala and had him buy it for me for payment for the work. Fit good. I didn't do to bad for my first time doing a cover. i didn't trim my filler close enough and that is the bulge on the drivers side top. But i'll get it better. I did find out the seat is not a 64 seat. had a tag on the frame on it that said May 19, 1961.
Old 04-25-2016, 03:27 PM   #2257
DPowers
One foot in front of the other
DPowers's Avatar
Originally Posted by 60chevyjim View Post
Dwaye your truck looks great !!
Thanks,
Amazing what some soap and water will do.
DPowers is offline
Old 04-25-2016, 06:29 PM   #2258
OldChevy61
OldChevy61's Avatar
Got most of one of my doors stripped.
OldChevy61 is offline
Old 04-25-2016, 06:33 PM   #2259
Lugnutz65
Lugnutz65's Avatar
That is not a small thing either! It's a lot of work.
My 65 C10 build: www.lugnutz65chevystepside.weebly.com
Want to know more about T5 transmissions? My website has a T5 Info Page and a Step by Step T5 rebuild.
Lugnutz65 is offline
Old 04-27-2016, 04:24 PM   #2260
OldChevy61
OldChevy61's Avatar
For sure Lugnutz. I got the glass and vent window out of the passenger door. Getting ready to strip the drivers door now.
Old 04-27-2016, 09:53 PM   #2261
TJ's Chevy
TJ's Chevy's Avatar
Installed new KYB gas shocks on my 64. Man does it ride ALOT better. Also installed new grease seals and you gotta have chrome hub caps. lol!
TJ's Chevy is offline
Old 04-29-2016, 04:58 PM   #2262
chevy2tom
chevy2tom's Avatar
Installed my new to me step bumper
&started recycling
Happy WTF...(Wire trash friday!)
chevy2tom is offline
Old 04-30-2016, 08:46 AM   #2263
my04
my04's Avatar
serviced rear diff., Eaton HO52, 4.57 gears...
my04 is offline
Old 05-01-2016, 03:54 AM   #2264
Oz_
Installed a quick fuel 450 carb. 283 is much happier moving down from the tired Holley 600.
Oz_ is offline
Old 05-01-2016, 12:29 PM   #2265
Isaiah92260
Isaiah92260's Avatar
How did you strip the pint? Did you sand or chemical strip? Funny I was standing my doors yesterday because I'm gonna get resdy to paint them Krylon Champaign Nuevuoe to imitate the light fawn, while I was standing, I was thinking, this is going to take way too long.
Isaiah92260 is offline
Old 05-01-2016, 03:24 PM   #2266
OldChevy61
OldChevy61's Avatar
Not sure about lugnutz, but I used a paint and rust stripper in my drill for 95% of it. Sandblaster. For the tight spots.
Old 05-01-2016, 03:28 PM   #2267
OldChevy61
OldChevy61's Avatar
Got my headers painted and installed and got the starter bolted on.
Old 05-01-2016, 08:26 PM   #2268
Lugnutz65
Lugnutz65's Avatar
Flat areas strip best with a 4.5" grinder and a HF poly carbide disc. This fender outer surface took about 45 minutes. Wear a dust mask and always watch the direction of disc rotation when coming to an edge. Smaller areas need a tighter radius so I use a wire wheel on a drill for that. Inside the window channels is best done with media blasting if you can.
I do NOT use chemical strippers for fear that any residue will prevent primer from bonding to the metal. Besides that, chemical strippers are expensive, caustic, and messy.
Old 05-01-2016, 09:04 PM   #2269
oldies1938
rims and tires are on....20" MOB STEEL WHEELS
oldies1938 is offline
Old 05-02-2016, 05:13 PM   #2270
TJ's Chevy
TJ's Chevy's Avatar
New radiator came in today!
Old 05-02-2016, 06:55 PM   #2271
chevy2tom
chevy2tom's Avatar
Adjusted the valves after break in. Hope to take it out for its(to me) maden voyage lol
Old 05-02-2016, 09:20 PM   #2272
steveb64
steveb64's Avatar
Worked on installing new bearings in the Cad 500. The thrust went out due to a high pressure transmission problem, which caused issues with the cam bearings.
Sorry about the sideways photo's, not sure why some do this and others don't, they're oriented correctly when I upload.
steveb64 is offline
Old 05-04-2016, 10:30 PM   #2273
TJ's Chevy
TJ's Chevy's Avatar
Got my new demon and slip yoke ordered from Summit this evening. Gonna measure the drive shaft and go have it shortened.
Old 05-04-2016, 11:11 PM   #2274
vin63
It's Better With Nitro
vin63's Avatar
Got the rear window in tonight...I'll put in the chrome lock strip this weekend.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline
Old 05-08-2016, 11:06 AM   #2275
TJ's Chevy
TJ's Chevy's Avatar
New demon and slip yoke!
Closed Thread
