Old 04-24-2016, 04:17 PM   #1
budman k20
1972 K20
Rear end swap questions...WWYD?
I'm building a 67 c10 (with 49K miles) that has a 6 lug posi rear. I also have a complete 72 chassis to swap out mileage unknown. I have read up and searched converting 6 to 5 lug rear ends. Both rears have 3:73 gears, and I want the posi either way. So I have to either put the posi unit into the wider 72 rear or put aftermarket 5 hole axles in the shorter 67 rear. I think it would be less work to put axles in the 67 rear.
So my questions are:
Would you use the 67 rear and why?
Would you use the 72 rear and why?
Are there fewer wheel backspacing options for the 67 over the 72?
Can I just bolt in the posi carrier in the non posi rear and not have to reset the ring and pinion gears? I'm guessing I would have to re-shim for backlash but not have to change pinion depth...
I plan on using the complete 72 disk 5 bolt front end.
Thanks in advance for helping me decide what to do!
budman k20 is offline   Reply With Quote
Old 04-24-2016, 04:39 PM   #2
sprint_9
sprint_9's Avatar
Re: Rear end swap questions...WWYD?
I would use the 67 simply because I like the wider dish it allows you to have with the rear wheels. If cost is an issue the 72 would be cheaper since you wouldnt need to buy aftermarket axles.
Either way I would have it gone through/rebuilt, cleaned up, new bearings, seals, check things over good.
sprint_9 is offline   Reply With Quote
Old 04-24-2016, 04:40 PM   #3
SS Tim
SS Tim's Avatar
The 71-72 (and late 70) rear is a little wider, want to say 1.5" to better match the wider front disc brake track.
If you swap the posi case you need to do a complete ring and gear reset. I for one don't even like transfering used gears but you never split a set.
Might want to consider the rear brake condition too unless you are planning new from the backing plate out either way.
SS Tim is offline   Reply With Quote
Old 04-24-2016, 05:11 PM   #4
budman k20
1972 K20
Yea I would keep the gear sets together and your comment about the disc rear made me wonder if aftermarket disc brake kits would be the same for either year rear? If there is no clear advantage to the 67 other than lower mileage I'm leaning towards putting the 72 rear on it.
Old 04-24-2016, 05:52 PM   #5
dennislbrooks
dennislbrooks's Avatar
I thot the 67 axles were shorter than the 72 axles, hence axle and those housings are not interchangeable --may be wrong. So if you want 5 lug to match the 72 front disc --use the 72 axle --switch the posi.
I think the 72 axles will extend too far from the 67 housing/tubes.
1942 Chevy 1/2 ton Rod, 1959 GMC 1/2 ton Fleet Stepside, 1967 Chevy SWB K10, 1985 Corvette Coupe 4+3, 2015 Chevy Duramax reg cab 4WD W/T
dennislbrooks is offline   Reply With Quote
Old 04-24-2016, 06:16 PM   #6
budman k20
1972 K20
Like I mentioned in my post the 67 axle is shorter. I have the equipment to re-drill to 5 lug and turn the 67 axles or I could buy aftermarket. I'm asking people to provide any known advantages to one or the other.
Old 04-24-2016, 06:28 PM   #7
dennislbrooks
oops -- I have redrilled also -- you have to drill or mill thru one partially welded hole as you know but can be overcome.
Old 04-24-2016, 06:28 PM   #8
SS Tim
SS Tim's Avatar
A wider axle (wms to wms) will allow a wider zero offset set wheel given the same suspension. In my book zero offset (or near to) is important on a semi-floating axle.
Old 04-24-2016, 06:30 PM   #9
jdalexa84
Amazon.com: Motive Gear MG6569 8.875" Axle... Amazon.com: Motive Gear MG6569 8.875" Axle...These are what I used. Fit great and not much more than a set up kit. Plus you have to buy tools to change it over and come out at about the same price and have to do more work. Might spend an hour if you really take your time with the new axles. If you go with the 72 rear end you are using 44 year old axles so who knows what they have been through
jdalexa84 is offline   Reply With Quote
Old 04-24-2016, 06:59 PM   #10
budman k20
1972 K20
dennislbrooks... no worries!
jdalexa84... Great price on new axles in a low mileage rear... have to think about that option.
SS Tim...the constant battle between form and function! I won't be hauling anything in this truck...but I do like to drive at a brisk pace so good handling is not lost on me either.
Old 04-24-2016, 08:00 PM   #11
68bowtie
68bowtie's Avatar
what wheels/tires are you planning on running?
Please help my sister in law with her battle with cancer https://gofund.me/902f6fce
Old 04-24-2016, 11:54 PM   #12
budman k20
1972 K20
Not sure yet. It is green and looks like this one. Same color and trim
I do like the salt flats or 338's depending on the costs?
Old 04-25-2016, 01:54 AM   #13
68bowtie
68bowtie's Avatar
that's one of my favorite trucks. you better be posting some pictures soon so we can all drool!
to answer the question though, if it was me i would figure out the exact wheel/tire combo and figure out what axle width would work best. if it would help avoid a custom wheel backspace or rear end mods that seems like the best route to me. i like summit racing for the interface and ability to filter wheel specs to pin down options.
Old 04-25-2016, 06:59 AM   #14
dennislbrooks
If needed - I have a pair of 5 on 5 - 1" wheel spacers with nuts that I will not use as my trucks are 6 or 8 or 4 3/4 x5 on the 42. I hope I am not scolded on the deadly sins of wheels spacers.
Old 04-25-2016, 10:35 AM   #15
budman k20
1972 K20
Well you wont drool over mine! It is a LWB right now but I have a 68 SWB frame and a 67 short bed and complete 72 chassis that I'm swapping out parts to make it the way I want it. Some people may call it a Frankenstein truck but I'm building it to my taste and putting the best metal on it I can find.
Old 04-25-2016, 04:49 PM   #16
mike16
all things being equal your best bet is to stick with what you have. a low mliage truck favors the origonal drive train too and the cost of simply switching everything over is not too cost effective. cheaper simply to buy the wheels you like in a six lug configureation.
mike16 is offline   Reply With Quote
