Old 04-25-2016, 07:31 PM   #1
JayJayB
Blue Sky
Here it is! I finally pawned my non-running, chopped up, beat to H-E-double toothpicks Chevy LUV off for this ol' thing. It's rough right now to say the least.
My plan for it at this point, since my budget is really tight, to get it moving under it's power. (don't get me wrong, I would love to restore it!) I can tell that the engine in it is not the original and has some issues anyway like a *shudder* 2bbl intake, no carb, no distributor, and no alternator brackets. I have a Mercruiser 5.7L with a 4bbl intake that's almost ready to go.
Sometime in it's life, someone converted it to an internally regulated alternator, then the brackets were robbed. The booster and master cylinder have been changed out for a later year as well (plastic reservoir). It has leaf springs on the rear (is that factory?). Not sure if the rear axle is factory either (it's locked up atm, too; I will pull the wheels and check the brakes at some point). It has no drive shaft at all. The transmission is questionable and not sure which one it is yet (can't get under it without getting really muddy atm). Not sure what else it needs at this point, mechanically speaking. Any info is appreciated.
For now, I have uploaded some pics here and if more are needed, let me know what angle to take them from and I'll do it. Thx!
"Time off"? What is this "time off" you speak of?.
JayJayB is offline   Reply With Quote
Old 04-25-2016, 07:34 PM   #2
JayJayB
Re: Blue Sky
More pics!
The glove box door isn't factory
Old 04-26-2016, 05:08 PM   #3
alsriv2
alsriv2's Avatar
Location: Formerly MD and San Diego, now loving life in Arizona
Re: Blue Sky
Looks like you have a good starter project. A 3/4 ton truck is nice. Your glove box door is probably original, but we would need to see a picture of the SPID label on the inside to determine. Yours looks like it could be a Cheyenne package or something similar due to the trim package that appears to be installed on the cab, the AC system installed, the paint option, etc etc. Include a picture of the SPID label so we can see what you have there.
Alan
2012 Ram 3500 Dually Crew Cab 6.7 Cummins
2014 Palomino Columbus 340RK 5th wheel
'69 Chevy C10 396BB
alsriv2 is offline   Reply With Quote
Old 04-26-2016, 08:56 PM   #4
JayJayB
Re: Blue Sky
To alsriv2;
Here's the pic of the SPID (the lie):
Please take note of the color scheme listed
Old 04-26-2016, 09:04 PM   #5
geunther
geunther's Avatar
Re: Blue Sky
Looks like glove box is from a different truck. Basing that on all the differences such as both interior and exterior colors. Behind where the cluster was I don't see any original orange paint indicating a color change.
geunther is offline   Reply With Quote
Old 04-26-2016, 09:06 PM   #6
JayJayB
Re: Blue Sky
One thing I wanted to add to the previous post was some info on the motor. Not sure which one it is, but found a stamping by the water pump mount on the passenger side.
1st line: F0912CEM
2nd line: 018l514034
Could anyone decipher it, please?
Also found this above that same part of the engine on the side of the head (not sure why it's upside down):
Old 04-26-2016, 09:14 PM   #7
geunther
geunther's Avatar
Re: Blue Sky
Originally Posted by JayJayB View Post
1st line: F0912CEM
1980 305 engine. Not the best of news.
Old 04-26-2016, 09:59 PM   #8
Wizo
Wizo's Avatar
Re: Blue Sky
Smog motor. Ditch it n' drop in a Rat. Looks like a decent start for a project truck.
1970 3/4 ton long box GMC
!968 C10 short stepside (Papa's Old Lorry)
2006 2500 HD Silverado Duramax/Alison
Wizo is offline   Reply With Quote
Old 04-26-2016, 10:27 PM   #9
JayJayB
Re: Blue Sky
Thanks for the info, geunther. I had my suspicions that motor was a "wolf in sheep's clothing". That mercruiser 350 is definitely getting dropped in there!
Old 04-28-2016, 06:04 PM   #10
JayJayB
Re: Blue Sky
I did some research on the engine I have going into my truck and it turns out to be a 1984 OMC Sterndrive 5.7. I did a compression test on it and it was satisfactory (don't remember the exact number). Just have to separate the TH400 from the dead 305 somehow.
Old 04-29-2016, 02:28 PM   #11
alsriv2
alsriv2's Avatar
Re: Blue Sky
To alsriv2;
The only way to know for sure is to take a look at the Vin number on the drivers door post and compare it to the Vin on the SPID label. While you are at it, compere the Vin on the door frame to the Vin stamped on the frame under the master cylinder area. At the very least, the frame and the door post should match.
Your truck has some good options anyway so put it together the way you would like to have it and enjoy!
Alan
'69 Chevy C10 396BB
Old 04-29-2016, 02:58 PM   #12
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Re: Blue Sky
Tight budget is gonna be hard to maintain with that rig.
I'd part it out...
Gary
'cuz chicks dig scars...
I would never rebuild a 305.
Old 04-29-2016, 06:22 PM   #13
frenchy51
frenchy51's Avatar
Re: Blue Sky
That could be a cool truck someday-you have your work cut out for you.
If the SPID is correct???it was my favorite color combo, but the existing blue paint looks original to it to me. Glove box door must be from another truck. I agree-check door vin with glove box vin and you'll know.
1972 Highlander PAC B 400BB-SOLD
1974 K5 Blazer-6.0 swap
1974 C20 Long Bed 454
1977 GMC HeavyHalf
several adopted orphans
frenchy51 is offline   Reply With Quote
Old 04-29-2016, 09:03 PM   #14
68350
68350's Avatar
Re: Blue Sky
Appears to have a high hump so I'm guessing it was a 402/th400 at one time. Sweet truck! Going to be a huge project but everyone starts somewhere
68 Chevy CST/10, 50th Anniversary, 327/th400, 373 posi, buckets
68 GMC Shortbox Stepside, 402/th400, Tilt, Tach, Bucket Seats, 3.08 Positraction
69 Chevy Camaro SS, 383, 4 speed, positraction
70 Chevy El Camino SS396, Triple Black, 454/th400, Tach
70 Chevy Shortbox Stepside 4x4, 350/th350, Tilt, Tach, Cab Lights, Bumper Guards, Tow Hooks
70 Chevy 3/4 Longbox, 350/auto, 70k, SURVIVOR
71 Chevy Blazer, CST, 350/auto
71 GMC Sierra K2500, 454, 4 speed, 4.10 posi, 37s
71 Custom/30, Open Road, 350/th400, tilt
72 Chevy Shortbox Fleetside, 496 Stroker/th400, Tilt, Tach, Bucket Seats, 3.42 Posi
72 GMC Sierra Grande 2500. 427/th400, tilt, a/c, tool and stowage, buckets/console, 3.54 posi
68350 is offline   Reply With Quote
Old 04-29-2016, 09:44 PM   #15
JayJayB
Re: Blue Sky
As far as getting this truck running, parts that my dad (Jake1971) has collected from users on this site and other misc. sources will aid me tremendously (I won't get them for free, though). I'm planning on restoring this truck when the money is there, hopefully in the next 2-3 years. For now, I want to enjoy it as it is; "farm fresh"!
The 305 I did try to crank and it's locked up. The passenger side door won't open atm. The tires are all bad. In spite of all this, I love it! I have wanted a truck like this for a very long time. For now, Cinco de Mayo is slated for an engine pull. Any ideas on how to separate the torque converter from a locked up engine?
Anyway, here's the VIN plate:
