Hood Shaking
For some reason, the hood on my 52 shakes while driving. It shakes on both sides, near the cowl.
Does anyone have any suggestions on how to solve this? Do the springs need to be replaced or does the hood need to be aligned better? I'll take a pic of the hood alignment tonight and post it. |
Re: Hood Shaking
Yes, post photos including from an angle to show how tight the hood is against the cowl. Realistically the springs help you open the hood, that is all they do.
Brian
1948 Chevy pickup Chopped, Sectioned, 1953 Corvette 235 powered. Once was even 401 Buick mid engined with the carburetor right between the seats! Bought with paper route money in 1973 when I was 15. "Fan of most anything that moves human beings" |
Re: Hood Shaking
Re: Hood Shaking
You might have too much HP under the hood and its trying to escape!
52 Chev 1300,55 235 40 over, 848 head, dual Edelbrock intake, Fenton headers, CW 32/32 carbs, 251 cam, HEI, T5 Trans, 3.23 rear, 235/75/r15 rubber. If it aint broke I still try to fix it! |
Re: Hood Shaking
any speed over 85 mph the hood on my 58 truk does crazy undulations
cool, an ogre smiley ![]() how to put your truck year and build thread into your signature shop air compressor timer |
Hollister Road Co.
Re: Hood Shaking
Your way out of adjustment on the hinges and not down on the anti squeak rubber. It is possible that its worn hinges but most likely just adjustments.
You can follow these instructions http://chevy.oldcarmanualproject.com...51ctsm1104.htm or stop by the shop and we'll show you how to do it |
#8 | |
Re: Hood Shaking
![]() Brian
Re: Hood Shaking
Maybe refresh the page? I see them in your quote of my first post.
Re: Hood Shaking
Yeah, that was weird, I see them now. Everything from Photobucket, yours and others were all messed up and not showing the photo, odd.
Anyway, yes, the hood simply has to go down in the back, a lot. The problem is, there is a big dance when doing these hoods. The fenders could be up too high too so that hood can't even go down. It looks like there is room but we would need more photos, ones showing the lower edge of the hood to the fenders. They are not easy to align, they often take movement all over the place to make them fit. But going down is most certainly needed. Brian
