Originally Posted by kajf9491
I know this thread is super old, but I've been searching high and low for an overdrive indicator for a non-tilt column. Someone on this forum has to have found a purchase part or a solution to this issue. Any help would be greatly appreciated.
Nope !! I bought an overdrive indicator and made it fit perfectly, but unfortunately the location of the letters and numbers didn't correspond to which gear you were in. The problem is that on the older TH350 transmissions, there's a big gap between "P" and "R". On the overdrive transmissions, the gap is the same for all gears.
The picture below shows the OD indicator installed, but I've since removed it and put the original back in.
