Old 04-22-2016, 10:53 PM   #1
'65 chevy lover
One coat frame paint?
I'm in a bind for cash and need to get my truck going. I still want to paint the frame, but wondering. Is there a paint that will do a good job with that one paint being the ONLY coat of paint on there?
Thanks for any help offered.
'65 chevy lover is offline   Reply With Quote
Old 04-22-2016, 11:20 PM   #2
vince1
Re: One coat frame paint?
Under the truck brushing on mine was done with 50/50 Tremclad and used engine oil. It is messy but eventually hardens up to something that doesn't look too bad.
I've painted patio railings with Krylon rust paint which can be bought in a liter or quart can.
Years ago I did a model A frame with Glazurit paint but it probably wasn't cheap and it was put over epoxy primer.
vince1 is offline   Reply With Quote
Old 04-22-2016, 11:43 PM   #3
Captainfab
60-66 Nut
I would suggest checking into John Deere Blitz Black or some type of industrial primer/paint.
If you have a Rodda Paint store in your area, they have some good industrial paints that aren't expensive.
Old 04-23-2016, 01:26 AM   #4
'65 chevy lover
Thanks, everyone.
Old 04-23-2016, 01:37 AM   #5
ruffrida2005
Member of the longbed union.
ruffrida2005's Avatar
Yeah your best bet is go go with an Epoxy primer. Make sure the frame is cleaned really good. You can just brush or roll it on. If you cant spray it.
Paul
88 GMC Crew Cab dually, 454/T400
64 LWB 400 HP 350/350T Bagged, under construction! Sold most of it!
92 S10 Iron Duke 5 speed, 5/7 drop for now. soon to be bagged. Sold http://67-72chevytrucks.com/vboard/s...59#post4637759
ruffrida2005 is offline   Reply With Quote
Old 04-23-2016, 11:17 AM   #6
vince1
Just remembered, my brother uses Cloverdale industrial enamels, which he swears by. I think they are two part and a fraction of the cost of other name brand paints. He has it tinted to any colour and paints cars, trucks, and equipment with it.
Old 04-23-2016, 08:43 PM   #7
badherb
badherb's Avatar
POR-15 and metal prep $85 for both on LMC Its the correct stuff and its very durable. Not to say I know exactly what should be used but this is what I have found through looking up what to use.
1960 SWB “Pops”
If you won't support our troops then stand in front of them!
badherb is offline   Reply With Quote
Old 04-24-2016, 12:01 AM   #8
60chevyjim
60chevyjim's Avatar
I used rustoleum and sprayed it after I sandblasted the whole chassis
$28 a gallon and a quart of acetone for $8 to reduce it to spray it .
before and after pictures .
60chevyjim is offline   Reply With Quote
Old 04-24-2016, 12:16 AM   #9
sprinter11r
sprinter11r's Avatar
go to a farm supply store and get a gallon of implement paint. Mix with laquer thinner. works great and cheap.
sprinter11r is offline   Reply With Quote
Old 04-26-2016, 11:29 PM   #10
'65 chevy lover
Thanks again to all for the reply's.
Old 04-27-2016, 12:03 AM   #11
'65 chevy lover
I was looking hard at the Tremclad paint however, can't seem to find it here in the USA.
Old 04-27-2016, 12:29 AM   #12
Thiessen1960
Tremclad in the USA is just Rustoleum. In Canada it is rebranded as Tremclad
Thiessen1960 is offline   Reply With Quote
Old 04-27-2016, 07:59 AM   #13
'65 chevy lover
Oh, thanks!
Old 04-27-2016, 11:44 AM   #14
earl84
I used Hammerite on mine. It's a rust encapsulator like POR-15. So far it's holding up well after about 1-1/2 years and 8000 miles. Had several colors to choose from. Bought it at Elliot's Hardware in Mesquite, TX when I was still living in Forney.
earl84 is offline   Reply With Quote
Old 04-27-2016, 11:25 PM   #15
60chevyjim
60chevyjim's Avatar
I brush painted the entire bottom of my 59 el camino 8 years ago with rustoleum when I restored it . the 59 body I painted with base/clear urathane.
the el camino is not garaged , its in a open carport and it still looks really good underneath after 8 years .
its the best deal for the money !!
then when I was building my 93 454 pickup I didn't have the money to buy paint to paint it after I did all the bodywork .
so for less than $75.00 I painted it two tone red n black with 2 coats of rustoleum from lowes and a harbor freight spraygun.
I painted it outside in janurary a year ago.
Old 04-27-2016, 11:35 PM   #16
Sik5chevy
I used 2 coats of por applied with a foam brush, let it cured, then scotch brite it with a red pad and top coated with black epoxy. It looks good and Its a driver, but if I were to do it again -i would probably epoxy primer and paint. Spi epoxy is pretty awesome by itself and not real expensive.
Sik5chevy is offline   Reply With Quote
