New headers, new headaches
I replaced the rusted and warped headers on my truck with new ones a few weeks ago. The new headers went in easy, and seemed to clear everything just fine, except for one spot at the passenger motor mount.
There is a tiny gap between the #2 primary tube and the motor mount, hard to see, but I can slide a credit card between the two, so it's not making contact (with the engine off). After driving around for a few minutes, I started to hear what sounded like metal vibrating on metal. I think it is the header rubbing on the motor mount (maybe it expands with the heat?) I've read that shimming the transmission (TH350) at the crossmember can help move the header away from the motor mount. Is this true? I know it is not the ideal solution, but I'd like to avoid getting another pair of headers (exhaust is already fabricated to fit these). I'd also like to avoid dimpling the headers, out of fear of ruining the ceramic coating.
Nick 1972 Chevrolet C10 Stepside |
Re: New headers, new headaches
What did you buy for headers?
______________________ www.northeastrodrun.com |
I bought the Summit Racing brand ceramic coated headers SUM-G9006-9
Maybe adding a few washers under the motor mount studs(assuming you have the stock motor mounts) that should keep them clear without doing too much "over-Engineering"
Ben ![]()
"Persistence is the twin sister of Excellence.one is a matter of quality,the other, a matter of time" ![]() “Serious Black” my 1971 Short Bed Fleetside Sold to an outstanding man in Lees Summit,Mo. “Gone, but by no means,Forgotten” |
I have these headers without clearance issues. My motor must be in a dif location than yours.
#6 | ||
I don't know if my motor mounts are stock, but they are as far forward as they can go. Here is a pic of the problem spot. ![]()
I've used fender shims on engine mount bolts (they're shaped like Us) so that you don't have to get the whole bolt out to shim it. If you use washers you have to take it all the way apart.
Give yourself a few extra 16ths because the motor will rotate and torque down in that direction under load.
1970 GMC Sierra Grande Custom Camper - Built, not Bought 1969 Pontiac 2+2 427/390 4-speed Coupe 1969 Pontiac 2+2 427/390 4-speed Convertible |
I had the exact same problem with mine....
1972 C/10 Cheyenne, Daily Driver. SOLD 1978 GMC K15 High Sierra. |
I chose to grind on and hammer my problem spot, which wasn't that bad and was more frame than motor mount... you may not want to do that, but since we're on the topic of header clearance.
https://www.youtube.com/watch?v=azPK...t5dIHutSOu7srE
Since the front mount would be the center of rotation. Adding shims under the trans mount would take far more shim to achieve clearance at the aft edge of the front engine mount stand than up fron where you need it.
BTW: What kind of condition are your mounts in?
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
put a block of wood under the pan, and gently lift the engine off the mounts and use the alignment shims as mentioned earlier, never thought about those clever!
Ben ![]()
#12 | ||
![]() The motor mounts seem to be in good condition. It's hard to tell just by looking at them, but the engine doesn't move around too much while under load. I don't know the details about them, they were on the truck when I bought it.
X2 - Check condition of motor mounts.
Boy do I know about motor mounts.....had a '64 Plymouth Fury once, rebuilt the engine and transmission in auto shop, one day I was showing off and brake torqued the tires, broke the left mount and ate my radiator for lunch...ouch, not to mention had to walk a few blocks afterwards...
![]() Ben ![]()
#15 |
![]() Join Date: Jul 2000
I'd be surprised if raising the rear of the trans does much good. I mean the header tube is right at the pivot point. It would be like lifting up one end of a see-saw and expecting the center to move up.
I've used thick, hardened flat washers between motor mounts and block, but in your case, I think it would be easier to relieve the spot where the tube is touching the bracket. That way there is zero chance of causing a new problem like shift linkage misalignment, fan hitting the shroud, hose or hard line getting stretched, etc.
Mike 1969 C10 LWB -- owned for 36 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, recent AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. 1982 C10 SWB -- converted from 250-six to roller cam 350, Vortec heads -- sold 1981 C10 Silverado LWB, 305, TH350C -- sold, but wish I still had it! 1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! |
#16 |
Why not put new mounts in? You can't tell by looking, they were on when you bought it, and if shims are enough to make it clear it's very possible that is to make up for lost thickness in mount cushion. What are we talking, 1/8-1/4"? The headers should be made to clear better than that, though.
#17 |
#18 |
Dude this post just helped me solve my "mystery noise" that I've been chasing for a week now lol couldn't for the life of me figure out where the intermittent squeak/tick was coming from. Here's an easy solution for ya. Get a flat screw driver or old chisel and tap it in between until there's a gap big enough to clear
#19 |
It makes sense to replace the mounts, they are cheap enough and I'll be lifting the motor anyways. I have a box of shims on hand, as well... If the new mounts don't do enough to resolve the issue, I'll shim them. I'll report back when it's complete and post the results.
Thanks for the info, fellas.
#20 |
I've been struggling trying to get the new motor mounts in, maybe somebody has some tips that can help me out?
The passenger side of the engine is done, everything is bolted in place, but the driver side is giving me a hard time. -There are three bolts that hold the mount to the block, I got the top two bolts in, but I can't get a wrench or socket around the bottom bolt. The perch gets in the way and I can't get any tools in the small gap to start tightening the bolt. -There is one bolt that holds the mount to the perch, and I can't get the hole to line up so I can thread the bolt in. At the moment, it seems like it would be easier to remove the perch from the frame, bolt the perch to the block/engine mount, then try to align the holes on the perch/frame and bolt that back in. It doesn't help that I'm doing this work alone in my driveway, it's pretty difficult to nudge the engine around from underneath the truck to try and get the holes to line up. Any suggestions?
Nick 1972 Chevrolet C10 Stepside Last edited by n33k0; 05-17-2016 at 02:28 PM. |
#21 |
Loosen the perch...the holes are elongated. I had the same issue when I changed mine to the poly mounts. Loosen both sides. It just take some finess, patients and a few choice words. I drove it awhile with the drivers side unbolted for a period thinking it would settle....not. Just had to keep at it. Even loosened the tranny mount.
1970 C10 Short Stepper with 71/72 front clip. |
#22 | |
