Old 04-28-2016, 11:15 PM   #1
YOLO
Custom Truck Lover!
YOLO's Avatar
Factory steering wheel on after market tilt column, HELP!
I want to run my factory steering wheel on an after market tilt column. Does anyone make an adapter? Has anyone figured out a trick for this? Thank you.
Squarebody guy
YOLO is offline   Reply With Quote
Old 04-29-2016, 12:00 AM   #2
vin63
It's Better With Nitro
vin63's Avatar
Re: Factory steering wheel on after market tilt column, HELP!
It depends on which column you're going to use. The Ididit retro tilt column for the mid-year GM trucks use the same spline as the GM steering wheels. I'm running an Ididit tilt column with the original steering wheel.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 04-29-2016, 12:52 AM   #3
oldies1938
i got a tilt from KevsClassics i am using my original 66 wheel
oldies1938 is offline   Reply With Quote
Old 04-29-2016, 05:33 AM   #4
Factory wheel should bolt up fine, but the horn connections, turn-signal canceling cam is not going to function correctly due to the big configuration differences.
Old 04-29-2016, 10:27 AM   #5
YOLO
Custom Truck Lover!
YOLO's Avatar
Thank you. So what are you all doing for a horn? Is it on the floor?
Squarebody guy
Old 04-29-2016, 10:50 PM   #6
On mine, I pulled the 64's one piece shaft and column and replaced it with one from a 69 C10. The 69 innards (probably like your tilt) matches to the more modern wheels and horn, etc. I used a era-looking model Comfort-grip wheel used on a lot of 67-68ish Camaros.
You can see it in my build thread.
I still have mine connected because of a bad horn kit, but I have a horn button on the dash under the headlight wiper switches. You can get them in most autoparts in the general accessories section.
