Old 04-27-2016, 09:17 PM   #576
62stepside longbox
62stepside longbox's Avatar
Re: A 15 year old's project. Rusty 62 stepside
Originally Posted by Grizz1963 View Post
Good work on the hood ornament so far.
It will always make you smile seeing it up front.
Of course I do like them a lot, so I am a bit biased.
Haha thanks rian
Nik...................____ 62 lwb c10 step-side 261 5 spd
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
my build thread. Sending unit solution
62stepside longbox is offline   Reply With Quote
Old 04-27-2016, 09:39 PM   #577
65sub
65sub's Avatar
Love the hood ornament Nik. It will make a nice custom touch.
Dale
My suburban's Twisted Little Sister
http://67-72chevytrucks.com/vboard/s...d.php?t=655167
65sub is offline   Reply With Quote
Old 04-28-2016, 01:24 AM   #578
62stepside longbox
Thanks Dale.
Even though I already painted the shifter I decided to go a different direction, a piston shifter. I got a lawnmower engine for free but it had some bad knocking in the bottom end when I fired it up plus it burned blue. So I pulled the piston and rod then cleaned it up. Then I put a little spring behind the wrist pin to increase the tension so it won't wobble around when driving
Old 04-28-2016, 10:21 AM   #579
TJ's Chevy
TJ's Chevy's Avatar
Cool! Looking forward to seeing how this turns out!
Old 04-28-2016, 11:23 AM   #580
62stepside longbox
Thanks, the one thing I need to figure out is how I'm going to mount the rod to the pre existing shifter
Old 04-28-2016, 02:34 PM   #581
Crappy drawing, but remove the one bolt for the bearing sleevd and make a same size threaded end on your shifter rod.
Hope that makes sense
Old 04-28-2016, 11:37 PM   #582
62stepside longbox
I ended up getting rid of the bearing cap and making a piece to bolt on
Old 04-28-2016, 11:40 PM   #583
62stepside longbox
Once it was bolted in place I then made little side covers out of plastic with a vinyl look to pretty things up and give it a cleaner look
Old 04-28-2016, 11:42 PM   #584
62stepside longbox
And here's a pic of it all finished up and installed. Now all I need to do is find a way to put the shift pattern on the top of the piston
Old 04-29-2016, 05:24 AM   #585
Leave it without the pattern. It confuses theives.
Work looks good!
Old 04-29-2016, 08:56 PM   #586
62stepside longbox
Work looks good!
Thanks bill, that is an idea but If someone else drives my truck I don't want them accidentally putting it in reverse when going down the highway lol.
Old 04-29-2016, 10:55 PM   #587
You could probably have a sign (or wrap) shop create some kind of sticker for it.
or
http://www.ebay.com/bhp/shift-pattern-decal
Old 04-30-2016, 01:52 AM   #588
62stepside longbox
or
Some of those look pretty nice. I may have to order one
Old 04-30-2016, 02:04 AM   #589
62stepside longbox
huge thanks to very nice guy! Member bfoley was kind enough to offer and give me some old school cool era correct gauges for my truck. What I received was two autometer gages, a oil pressure and water temp that have a vintage look to them. And two super cool Stewart Warner gauges, a vaccum gauge and an ammeter. He also threw in a couple of sweet toggle switches. Thanks again Ben.
Old 04-30-2016, 02:06 AM   #590
62stepside longbox
The cool Stewart Warner gauges
Old 04-30-2016, 02:07 AM   #591
62stepside longbox
And the toggle switches
Old 04-30-2016, 05:30 AM   #592
Old 04-30-2016, 09:20 AM   #593
rusty76
rusty76's Avatar
Cool stuff.
http://67-72chevytrucks.com/vboard/s...d.php?t=581873
The low buck build threads. Check'em out!
http://67-72chevytrucks.com/vboard/s...d.php?t=666022
My build thread
Crossmembers CC
rusty76 is offline   Reply With Quote
Old 04-30-2016, 11:29 AM   #594
TJ's Chevy
TJ's Chevy's Avatar
Neat stuff!!!
Old 05-04-2016, 01:21 AM   #595
62stepside longbox
Haven't been able to get much done on the truck lately because of another project I've been Working on and I'm pretty deep into it, I thought I'd show you guys. Doing a full rebuild on my xr100 plus a big bore kit that will make it 120cc and also a new clutch, tires etc. I should have it all wrapped up in the next couple days and be able to get back on the truck.
Old 05-05-2016, 01:03 AM   #596
62stepside longbox
Didn't get a whole ton done on the truck today but I did finish off the hood plane and I have to say she is real purdy.
Old 05-05-2016, 08:45 AM   #597
RANDY COX
RANDY COX's Avatar
Kool ornament. Looks like the center lines in the hood could be jet streams coming out of the back.
1964 BBC 402 4x4
RANDY COX is offline   Reply With Quote
Old 05-05-2016, 06:56 PM   #598
62stepside longbox
Thanks randy, yes that is probably my favourite part of the 62-66 hoods but I do favour 60 hoods which is what I'm going to use. I have seen somebody on here have the best of both hoods by taking the lines from the later hood and welding it into the earlier hood. But my 62 hood is to nice to chop up so I don't think that'll be happening.
Old 05-06-2016, 11:18 AM   #599
62stepside longbox
Got everything on the engine and engine bay all buttoned up and I'm confident it will run well this time. I just want to get the right tranny fluid before I run it anymore so it may be a few days. Oh and I managed to find a 60-62 v8 hydraulic clutch bellhousing that I'm picking up this weekend for a great deal just in case I ever want to go v8 in the future
Old 05-06-2016, 11:43 AM   #600
Johnny_Lamebridge
Johnny_Lamebridge's Avatar
Hey Nik, did you ever figure out your intake leak problems?
My 63 C10 SWB Fleetside (converted to BBW):
http://67-72chevytrucks.com/vboard/s...58#post6851558
@johnny_lamebridge on Instagram
Johnny_Lamebridge is offline   Reply With Quote
