Old 05-02-2016, 11:57 AM   #1
snipescastle2
snipescastle2's Avatar
Talking solution to power brakes for engines with "lumpy" cams
Hello all! I just wanted to share an idea I got from the internet. I read where Audi A4's and a lot of Volkswagen cars had electric Vacuum pumps for their vacuum assisted brakes.
I visited my local Pick n pull yesterday after work, found one on a 2003 Audi
A4, paid $26.00 and headed home. I brought it into work this morning, cut the hose barb off the business end, threaded it for 1/8" NPT and hooked up a vacuum gauge, then connected the leads to one of my De Walt batteries to test it, this little Sucker (Pun Intended) made 25" of Vacuum without breaking a sweat! I'm making a bracket to mount on the firewall and once I have it installed and tested, I'll let you know the results. I took a couple of pics to show my test, but they must be queued up on the mail server at work, so I'll post after while.
Have a good one!
Ben
"Persistence is the twin sister of Excellence.one is a matter of quality,the other, a matter of time"
“Serious Black” my 1971 Short Bed Fleetside Sold to
an outstanding man in Lees Summit,Mo. “Gone, but by no means,Forgotten”
snipescastle2 is offline   Reply With Quote
Old 05-02-2016, 12:15 PM   #2
davepl
davepl's Avatar
Re: solution to power brakes for engines with "lumpy" cams
Cool! I guess the only downside would be how often it can make enough vacuum to satisfy the brakes.
Heck that's a cheap source for a vacuum pump in general, I'm sure I paid a lot more than that for one to vacuum down my AC system!
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 05-02-2016, 12:40 PM   #3
MikeB
MikeB's Avatar
Will be interesting to see if it works. I guess it will depend on how much the booster volume decreases the vacuum when brakes are applied.
Dave, an AC vacuum pump needs to pull 29" vacuum to boil moisture at temperatures less than 80 degrees F, so they typically cost more. The really good (and expensive) ones will approach or exceed 29.9".
Mike
1969 C10 LWB -- owned for 36 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, recent AAW wiring harness, 5-lug conversion, 1985 spindles and brakes.
1982 C10 SWB -- converted from 250-six to roller cam 350, Vortec heads -- sold
1981 C10 Silverado LWB, 305, TH350C -- sold, but wish I still had it!
1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming.
Retired as a factory automation products salesman.
Worked part-time over the years for an engine builder and a classic car repair shop.
Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then!
MikeB is offline   Reply With Quote
Old 05-02-2016, 01:47 PM   #4
GMC Canuck
Maybe with a canister if the pump doesn't have the volume.
Interested to hear how it works.
Will the pump run all the time?
How noisy is it?
GMC Canuck is offline   Reply With Quote
Old 05-02-2016, 02:02 PM   #5
AirSpeed
AirSpeed's Avatar
I bought a gm vacuum pump, tank and vacuum switch on Amazon, made an aluminum mount on my cnc and mounted it to the firewall, it really works great! Get about four stops before the vac pump turns on. Very happy with it!
AirSpeed is offline   Reply With Quote
Old 05-02-2016, 03:44 PM   #6
cleszkie
cleszkie's Avatar
Does that have a pressure regulator built in? It should only cycle occasionally when the vacuum goes below a certain limit. It should also stop when the max vacuum is achieved. Otherwise, that pump will wear out from continuous use.
cleszkie is offline   Reply With Quote
Old 05-02-2016, 03:58 PM   #7
AirSpeed
AirSpeed's Avatar
Mine came with an external adjustable vacuum switch. After about 3 or 4 stops it runs for around 20/30 seconds. I tested mine one day during some stop and go traffic and after about 45 minutes of driving it was still pretty cool. You really need a vacuum tank to make it work properly. I had to turn mine down or the brakes got really sensitive.
Old 05-02-2016, 04:04 PM   #8
AirSpeed
AirSpeed's Avatar
How noisy is it?
Mine is pretty quiet, the only time I hear it is at an idle, it's a nice humming sound, not annoying at all. It has rubber bushings to help quiet it down, I mounted it to the right of my brake booster so it's pretty close to me.
Old 05-02-2016, 09:13 PM   #9
snipescastle2
Talking Re: solution to power brakes for engines with "lumpy" cams
Out in the open it's kind of noisy, but I think once it's installed and plumbed up to the tank and booster shouldn't be too noticeable. Here is a couple of pics...
Ben
Old 05-02-2016, 09:17 PM   #10
snipescastle2
Another...
Old 05-02-2016, 09:45 PM   #11
CST10
CST10's Avatar
Sweet idea. Thanks for sharing.
MyToys:
Goldilocks the "Ol School Survivor" 1968 C10, SWB Stepside, 08/15 TOTM, 250 CI 6 cylinder, 3 on the tree, 3.73 rear, 3/5 static drop, 23,500 original miles.
Samson the 1970 CST10, LWB, 462Ci, Turbo 350 tranny, 3.08 rear gear, PB, PS, A/C, AM/FM, 2/4 Drop.
Brutus the 1998 Camaro Z28, 33,500 original miles, LS1, 519 RWHP/497 RWTQ.
Member of the Louisiana Classic Truck Club, LCTC
Member of the Louisiana C10 Club
Member of the Baton Rouge Drifters Car Club
CST10 is offline   Reply With Quote
Old 05-02-2016, 10:10 PM   #12
AirSpeed
AirSpeed's Avatar
Ben
Mine was noisy before I mounted it but it's a nice purr now. Yours looks a lot like the one I bought.
Old 05-27-2016, 04:59 PM   #13
snipescastle2
well, I have yet to try it out, but I did get an adjustable vacuum switch, cycles the pump on at 18 inches of vacuum, just haven't had time to test it out on the truck yet. I made a Vacuum accumulator out of a 5 pound oxygen bottle, couple that with all the braided hose I should have quite a good vacuum supply.....
Ben
