newer 3/4 ton wheel swaps
been searching the forum trying to get pictures of some '81-'87 suburbans with some '03-'07 8 lug wheels with the screw on center caps. im looking for these wheels
on my rig here any pics, or info on getting the right lug nuts for the center caps to screw to would be great, thanks guys
'83 GMC K2500 Suburban 4x4
2000 Chevrolet Silverado 1500 Z71 4x4 God Bless America!!!! ![]() |
Re: newer 3/4 ton wheel swaps
I've got a set of 17" wheels from a 2010 Silverado on my Suburban. They fit fine but I just leave the center caps off.
1990 ¾ ton 4x4 Chevy Suburban -Cummins Diesel - 12 valve - factory rebuilt -6 speed bullet proof manual transmission - NV5600 -Gear Vendors Overdrive - HX35 Holset Turbo -NP205 iron transfer case -3.73 gears -2" Lift |
Here's some on my suburban.
![]() 1987 R20 Suburban LQ4/4L80e swap: http://67-72chevytrucks.com/vboard/s...d.php?t=693824 |
Those look great, now do those have the same backspacing at the stock wheels? Or are they offset in or out a little more? And did the lug nut's from a newer truck work on the factory studs or is the thread a tad different? Thanks
I'm also looking to plasti dip the wheels and have the chrome center caps on the black wheels. does anybody know the best, most durable plasti dip to use? I live on a dirt road and rocks chip everything.
Not too sure, they were on the truck when I bought it. They fit great, no rubbing, clears brake caliper, and looks like the used the lugnuts that came with the newer wheels not the lug nuts from 1987. Hope this helps.
