Re: Camp and cruise, 72 Jimmy 4wd Project
Good to see that it went to a good home. I contemplated looking at it decided not to as I already have four of them. As for your question about the doors being cut down I would guess that at least the drivers side has been. There is no hole next to the wing window for the screw so the door is 71 or older. The reinforcement plate around the latch should be spot welded on also. If your Jimmy is a 72 it would have had moulded plastic door panels. Where are you in Utah if you don't mind me asking?
