Old 05-02-2016, 03:51 PM   #1
Bruin_26
High RPM
Hey guys, so I finally have my '72 C20 back on the road but I have one issue with the truck running at high Rpm when I'm running at highway speeds. Everything seems run fine when I'm cruising below 40 mph but when I try to pick it to highway speed it jumps to almost 4000 RPM and stays there. Just wondering what the possible culprits could be.
Thanks in advance for any responses!
Bruin_26 is offline   Reply With Quote
Old 05-02-2016, 04:03 PM   #2
cleszkie
cleszkie's Avatar
Re: High RPM
Manual or auto tranny? Carb or EFI? Throttle linkage sticking? Auto tranny kick-down cable not adjusted properly and kicking down too soon? We need more info on your setup to make a diagnosis.
cleszkie is offline   Reply With Quote
Old 05-02-2016, 06:50 PM   #3
hamjet
hamjet's Avatar
Re: High RPM
A C-20 with 350 CI comes with a 4:10 gear ratio I think, 4:56 optional. That would do it...As cleszkie says, we need more info.
Thanks, Joe..
1969 C/10, 348 C.I., 3X2 bbl. V8, 2004r , LWB.
hamjet is offline   Reply With Quote
Old 05-02-2016, 06:55 PM   #4
Jack_71C10
Shortbed club member
Jack_71C10's Avatar
Re: High RPM
Sounds about right, unless you replaced the transmission with one with an overdrive.
71 custom/10 6.0/4L80E SWB ece 4/6
72 custom camper 350/3 spd
2020 Chevy Express 3500
2023 Hyundai Tuscon
1986 GMC 3500 Bucket Truck
Sent from my Rotary Phone via 14.4kb/s modem.
Jack_71C10 is offline   Reply With Quote
Old 05-02-2016, 07:14 PM   #5
Bruin_26
Re: High RPM
So it's a 4 barrel quadrejet, stock automatic transmission and don't think the throttle linkage is sticking.
Old 05-02-2016, 08:13 PM   #6
Alex V.
Alex V.'s Avatar
Re: High RPM
By "jump" do you mean engine speed increases all of a sudden without an equal increase in ground speed, or that it just has to spin 4K to do highway speed?
Alex V.
1967 C10 Suburban, 350/NP435, Green/Green, PS, PB, HD cooling, charging, shocks, and springs.
1985 GMC C3500 SRW, Sierra Classic, 454/TH400, white/blue.
Alex V. is offline   Reply With Quote
Old 05-03-2016, 12:28 AM   #7
toolboxchev
Re: High RPM
My stock 350 with turbo hydramatic 350 transmission runs at approximately 3200 at 60 -64 mph.
At what speed are you going when you are hitting 4000 rpm? If my truck were doing that kind of rpm I would be hitting 80-85 easily.
Sounds like you are stuck in 2nd gear, or the kick-down on the transmission is engaging and may need adjustment at the carburetor.
Most Motor heads may agree.
toolboxchev is offline   Reply With Quote
Old 05-03-2016, 06:51 AM   #8
Ken B
Re: High RPM
My 1970 C30 with a 350 and 4 speed with 4.10's turns 3000 rpm at 62 mph.. I think your tranny might be toast and is slipping or you aren't getting into 3rd gear...
Ken B is offline   Reply With Quote
