Old 05-04-2016, 10:32 PM   #1
Rustyo61
Re: question on 61 motor swap
OK so I think you helped me figure out my problem my mounts only have 1 hole in the foot and 2 on the top frame rail.
Rustyo61 is offline   Reply With Quote
Old 05-04-2016, 10:46 PM   #2
Rustyo61
Are you using clash ell style mounts?
Old 05-04-2016, 10:50 PM   #3
TheGreen61
These are the mounts I have. I still have the original crossmember in place though so I just drilled all new holes.
Waiting on a couple parts still then I'm swapping it all over to the 85 crossmember and suspension/steering stuff.
TheGreen61 is offline   Reply With Quote
Old 05-04-2016, 10:55 PM   #4
Rustyo61
I have a stock set out of a 72
Old 05-04-2016, 11:35 PM   #5
TheGreen61
Like these?
Old 05-05-2016, 12:36 AM   #6
Captainfab
60-66 Nut
If they are for the 230/250 I6, those are intended to bolt in, in the rear set of holes. If you have the brackets for a small block, those are intended to bolt in, in the forward set of holes. However since you are working with a '61 frame, those are shorter in height. So the '67-'72 small block engine mount frame brackets fit nicely in the rear holes of the crossmember and no spacer to maybe 1/4" spacer on top of the frame.
Old 05-05-2016, 06:32 AM   #7
Rustyo61
OK so they look like the ones in picture got from a member here. Said they came out of a 72 c20 but they are shorter than the ones in picture and the top is on a angle not straight like the picture. With the top sitting on frame there is about half inch or so short of the bottom reaching the whole.
Old 05-05-2016, 08:35 AM   #8
Rustyo61
http://67-72chevytrucks.com/vboard/a...1&d=1462451632
