Old 05-02-2016, 10:21 AM   #1
1moretoy
Bleeding Brakes
Hey guys quick question on the brakes. All components are brand new. Calipers, manual master cylinder and lines. Calipers are C6 Zo6 corvette and a Willwood master. I asked A friend of mine who is a mechanic about bench bleeding the master before installing it. I didn't want to mess with fluid getting everywhere when hooking up the lines. He said to just use his vacuum system to bleed the system and not to worry about bench bleeding the master. What are your thoughts on this?
1moretoy is offline   Reply With Quote
Old 05-02-2016, 10:23 AM   #2
Rickysnickers
Rickysnickers's Avatar
Re: Bleeding Brakes
Well, I would say that you should bench bleed your new master. I have a Wilwood unit as well. With the parts and bits they include with their master, it makes it very easy and it really isn't that messy.
Old 05-02-2016, 11:13 AM   #3
RichardJ
Re: Bleeding Brakes
As you suspected, bench bleeding is a bunch of hooey on a horizontally mounted master cylinder. Bench bleeding became important in the 70's when they started mounting the MC at crazy angles. As you can see in this image, there is air trapped in front of both pistons. The fluid is level with the vent holes preventing the air from escaping into the reservoir. Mounted level the air will escape on its own. Sometimes a couple of taps with a wrench will encourage any persistent air bubbles to pop out.
You can go to great lengths trying to keep air from entering when you remove the plugs or bleeder lines, but guess what. It's still going to happen. Unfortunately, with a high angle mounted MC, you usually do need to bench bleed.
'67 GMC 2500, 292, 4spd, AC
RichardJ is offline   Reply With Quote
Old 05-02-2016, 11:33 AM   #4
1moretoy
Re: Bleeding Brakes
My master Is pretty level. You can see it in the picture.
Old 05-02-2016, 11:45 AM   #5
davepl
davepl's Avatar
Re: Bleeding Brakes
That's kind of funny because I had a talk with a respected tech who was installing a new master without bleeding it. I was kind of disappointed, like he was skipping a step, something I didn't expect he'd do.
At the time, however, he had the back of the car 5 feet in the air to make the master level to the ground. Which accomplishes, I guess, the exact same thing! Shouldn't have doubted him :-)
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 05-02-2016, 11:47 AM   #6
1moretoy
Re: Bleeding Brakes
So do you think I'm ok not bench bleeding?
Old 05-04-2016, 03:51 PM   #7
1moretoy
Re: Bleeding Brakes
Anyone else have any input. I would like to finish this up this week.
Old 05-04-2016, 06:24 PM   #8
tdangle
tdangle's Avatar
Re: Bleeding Brakes
I was always under the impression that you bench bled the m/c was so you wouldn't have as much work to do bleeding the entire system at each wheel. What is the difference between pushing the air out at the connection to the m/c or wheel cylinder?
Terry
1970 Custom Camper/C20 , GM Crate 350/7004R, Dana 60, factory AC
tdangle is offline   Reply With Quote
Old 05-04-2016, 11:51 PM   #9
LPoole
LPoole's Avatar
Re: Bleeding Brakes
Just recently added power brakes to my 68 fleet. Mounted the new m/c booster combo then bled it on the truck using the plastic hoses they provided and had no problems.
Better to remain silent and be thought a fool than to open your mouth and remove all doubt. - Mark Twain
LPoole is offline   Reply With Quote
Old 05-05-2016, 12:46 AM   #10
70SBC10BOB
70SBC10BOB's Avatar
Re: Bleeding Brakes
Been a certified tech for 40 plus years and vp of a brake company.
Always bench bleed the m/c. When you try to bleed them on the vehicle, you may not make the piston travel the full stroke of the m/c, that leaves a bubble at the end of the m/c bore. Bench bleeding takes any doubt out of the equation.
With all the work we put into making these trucks nice, why risk a no brake situation if the bubble travels into the system?
Nice drawings RichardJ
That's my 10 cents worth (it used to be 2 cents but we had inflation.)
1970 C 10 A work in progress!!
70SBC10BOB is offline   Reply With Quote
