Moderator
![]() ![]() Join Date: Aug 2011
Re: Volt Gauge Conversion Kits
I would like to buy one of these when you have one available. Thanks
Cluster King
![]() Join Date: Nov 2012
Hey Guy's,
I will do volt gauge conversions but I need to find the gauges. As most of you know, it is the 76+ Chevy truck volt gauge I use for these. If you have access or can find your own gauge, I can build a conversion for you if you send me the gauge. I will start working on getting some more gauges. The problem is the price on the gauge is costing more so I am going to be charging more for the conversions. They are going to be more around $100.00 shipped now if I supply the gauge. As far as the 60-66 volt gauge conversions, I can do those as well but the price will be $140.00. There is much more modifications to be done to the gauge tin to make them work. Also there is no "8-13-18" volt overlay for these like there is on the 67-72 conversions. Thank you for the interest. Send me an email to tbonegarris@yahoo.com if interested. Take care, Tom |
#4 | |
Moderator
Cluster King
The cluster has the main tin which you could call the main body of the cluster and it has the small tins that hold the gauges. The temp and amp gauge are in one tin and the oil and fuel gauge are in another tin. It is that "tin" that needs to be modified to accommodate a later style volt gauge.
Hope this helps, Take care, Tom |
Tom do you have any of these ready to be shipped? either in the 67-72 or the 75+. I am not sure which one I want. i am leaning towards the 75+ but not sure of any modifications needed to fit it. Will i need to put my needle on it?
1967 c10 3OTT with R10 overdrive. 385 Stroker, 373 posi FITECH EFI, Vintage air, York 210 OBA, 4/6 drop with riddler 20x8 and 20x10 1957 S5T Leslie Supertyfon train horns and EMD bell "No bolt left unturned" |
Cluster King
