4.8 parts on 6.0
Hi all, I pulled a 4.8 out of a 2001 silverado. Then I bought a 2002 truck 6.0 thats missing wiring harness, all accessories, pulleys, starter and flexplate. Will the 4.8 stuff bolt up? I will be putting a 2003 4L60e from a Savanna behind it.
thanks! Matt |
meowMEOWmeowMEOW
Re: 4.8 parts on 6.0
Everything should bolt up fine, just be careful with the flexplate. There is that spacer that some 6.0's had in order to fit with a 4l80e. You shouldn't need it for the 60e, but if its there by accident, your trans won't fully line up.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING ![]() |
Perfect, thanks!
