Old 05-07-2016, 01:19 AM   #601
62stepside longbox
62stepside longbox's Avatar
Re: A 15 year old's project. Rusty 62 stepside
Originally Posted by Johnny_Lamebridge View Post
Hey Nik, did you ever figure out your intake leak problems?
I believe so, I will find out for sure in the next day or two when I get it fired up
Nik...................____ 62 lwb c10 step-side 261 5 spd
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
my build thread. Sending unit solution
62stepside longbox is offline   Reply With Quote
Old 05-07-2016, 09:53 AM   #602
TJ's Chevy
TJ's Chevy's Avatar
Originally Posted by 62stepside longbox View Post
Didn't get a whole ton done on the truck today but I did finish off the hood plane and I have to say she is real purdy.
Hood bird looks good!
Old 05-07-2016, 02:18 PM   #603
62stepside longbox
Thanks tj
Old 05-07-2016, 04:22 PM   #604
Waiting....No truck noise yet.........waiting.....No truck noise yet...waiting..... Is it time yet??
Old 05-07-2016, 04:33 PM   #605
62stepside longbox
Not yet bill, but I did find out that I need synchromesh transmission fluid for the t5 which here in Canada will cost $50 just to fill the tranny, when will the costs stop?!
But on a positive note I did finish rebuilding the engine for my dirt bike, I did a big bore kit, clutch and bigger valves. http://youtu.be/_hzehgbL5mM so now I'll get to spend some more time on the truck.
Old 05-07-2016, 09:25 PM   #606
62stepside longbox
Just filled up the t5 with penzoil's finest. Got it started up and right away I could tell that the gasket is now sealing. It's really quite, except for backfiring. Yep still having problems. It starts easily now but it just won't idle, I have to keep the rpm's up then it just backfires and usually dies. I've played around with the air fuel mixture screw and just can't get it to idle or run smooth. Here's a video http://youtu.be/k-DiHR2XeO4
Old 05-07-2016, 10:53 PM   #607
62stepside longbox
Oh never mind guys, once it warmed up it would run smoothly but would idle too low and then die. I bumped the idle up and it runs great now, idles at 300rpm. Exhaust has a nice sound to it. http://youtu.be/0Zxcsv9oupM
Old 05-08-2016, 01:44 AM   #608
60chevyjim
60chevyjim's Avatar
that's great to here that it is fixed
60chevyjim is offline   Reply With Quote
Old 05-08-2016, 02:11 AM   #609
62stepside longbox
Yes it is!
Old 05-08-2016, 10:01 AM   #610
TJ's Chevy
TJ's Chevy's Avatar
Sounds Great man! Good job!
Old 05-08-2016, 12:49 PM   #611
62stepside longbox
Thanks tj, She sure does!
Old 05-08-2016, 11:00 PM   #612
62stepside longbox
Got a bit of work done on the rig today, fabbed up an inner rocker for the passenger side. Still needs some grinding but it's starting to take shape
Old 05-09-2016, 06:32 AM   #613
CURSED GEARS
Glad you got it running right, always a big relief. On your piston shifter, I wonder if a engraving shop could cut your Shifter pattern in it for you? Then you cut put some paint in the new reliefs? Just a thought. I'm enjoying watching you work on this
CURSED GEARS is offline   Reply With Quote
Old 05-09-2016, 10:03 AM   #614
scoot_mcgrute
Awesome man! Starting it is always a high point in the build
1966 Army Truck
http://67-72chevytrucks.com/vboard/s...d.php?t=691778
scoot_mcgrute is offline   Reply With Quote
Old 05-09-2016, 10:38 AM   #615
62stepside longbox
Thanks, it still needs a bit of tuning but it's running pretty well. That's what I was thinking for the shifter if I could get it engraved then paint then sand with a high grit paper, since the engravings wouldn't be touched by the sand paper they would be the only remaining paint if that makes sense.
Thanks Scott, yeah it sure feels good to get it running
Old 05-10-2016, 11:11 PM   #616
62stepside longbox
Got quite a bit done after school. I finished making the inner rocker panel and got it fully welded in, now it just needs to be ground smooth.
Old 05-11-2016, 10:14 AM   #617
TJ's Chevy
TJ's Chevy's Avatar
Nice!
Old 05-11-2016, 12:41 PM   #618
BFoley
BFoley's Avatar
Nice work as always. How long did it take you to weld in the inner rocker? How do you go about doing it? Do you tack a few spots here and there and then let cool for a while?
'66 GMC K25 (305 V6, SM420) aka "Mabel"
Link to project http://67-72chevytrucks.com/vboard/s...d.php?t=698082
All gone - '66 CJ5, '69 C25, '69 C25 Camper Special, '79 C10 Big Ten/Bonanza, '84 K10 Silverado
BFoley is offline   Reply With Quote
Old 05-11-2016, 02:02 PM   #619
62 Barnfind
62 Barnfind's Avatar
Nice work!
John Z
1962 Chevy C10 Stepside
62 Barnfind
My build tread: http://67-72chevytrucks.com/vboard/s...d.php?t=507513
62 Barnfind is offline   Reply With Quote
Old 05-11-2016, 02:19 PM   #620
66ChevyMax
66ChevyMax's Avatar
Very nice work Nik
Craig
1966 Chevrolet C10 - Supercharged LS3
1968 Chevrolet Camaro
1957 Chevrolet 2dr Hardtop
"It makes sence if you don't think about it"
Mesquite 1966 C10 - LS3 W/ Air Ride
http://67-72chevytrucks.com/vboard/s...=1#post4989763
66ChevyMax is offline   Reply With Quote
Old 05-11-2016, 05:02 PM   #621
62stepside longbox
Nice!
Thanks tj
Thanks Ben
It took about 15 minutes of welding. It's ok if the metal heats up a bit since it is part of the floor and it's all covered by the rocker and floor mat. I usually tack a couple places then use a small hammer to persuade it into the spot I want then more tacking.
Originally Posted by 62 Barnfind View Post
Nice work!
Originally Posted by 66ChevyMax View Post
Very nice work Nik
Thank you
Old 05-11-2016, 10:15 PM   #622
62stepside longbox
I thought I'd show you guys a donor truck I'm picking up in the next week or so.
1978 GMC Sierra that is complete minus the motor. $300. I will be using the front crossmember for the 62 so I can have disk brakes and cheaper front end parts. I'll also use the rear axle plus all four 15" 5 lug steeleies so that it is 5 lug all around instead of having 5 on the front and 6 on the rear. I'm considering also doing power steering.
Old 05-11-2016, 10:16 PM   #623
62stepside longbox
02
Old 05-12-2016, 10:02 AM   #624
TJ's Chevy
TJ's Chevy's Avatar
Good find!
Old 05-12-2016, 10:21 AM   #625
Johnny_Lamebridge
Johnny_Lamebridge's Avatar
That '78 will provide lots of good parts. I'd recommend doing the power steering. It sure is nice to have when you're backing into a tight parking spot at a cruise night surrounded by spectators.
My 63 C10 SWB Fleetside (converted to BBW):
http://67-72chevytrucks.com/vboard/s...58#post6851558
@johnny_lamebridge on Instagram
Johnny_Lamebridge is offline   Reply With Quote
