Closed Thread
Old 05-08-2016, 05:50 PM   #2276
62 Barnfind
62 Barnfind's Avatar
Re: What did you do to your truck today part III
Pulled the engine again. Possible spun bearing.
John Z
1962 Chevy C10 Stepside
62 Barnfind
My build tread: http://67-72chevytrucks.com/vboard/s...d.php?t=507513
62 Barnfind is offline
Old 05-09-2016, 10:51 AM   #2277
jbgroby
jbgroby's Avatar
Mounted the bumper Saturday and License Plate Bracket. Only thing left if the door glass, Hopefully this week some time.?
jbgroby is offline
Old 05-10-2016, 08:41 PM   #2278
Backpayne
I installed a new Weber 32/36 and she runs! Woo-hoo! She idles smooth and there is no black smoke from running ridiculously rich! Goodbye Rochester B!
Backpayne is offline
Old 05-10-2016, 09:03 PM   #2279
TJ's Chevy
TJ's Chevy's Avatar
Now where are the pictures?!??! Or the video!?!?!?!
TJ's Chevy is offline
Old 05-10-2016, 09:11 PM   #2280
Lugnutz65
Lugnutz65's Avatar
I sent you a PM. Needing a little advice about my Weber.
My 65 C10 build: www.lugnutz65chevystepside.weebly.com
Want to know more about T5 transmissions? My website has a T5 Info Page and a Step by Step T5 rebuild.
Lugnutz65 is offline
Old 05-11-2016, 12:18 AM   #2281
Backpayne
I meant to, just too excited!
Old 05-11-2016, 09:47 AM   #2282
vin63
It's Better With Nitro
vin63's Avatar
Started to make my cuts to the bed wood and strips for the access panels to the rear end housing and gas tank fillers. Next will be making the cuts for the widened wheel tubs.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline
Old 05-11-2016, 12:37 PM   #2283
OldChevy61
OldChevy61's Avatar
Passenger door worked,epoxied and urethaned. Ready for blocking. On to the other side.
OldChevy61 is offline
Old 05-11-2016, 10:28 PM   #2284
TJ's Chevy
TJ's Chevy's Avatar
Scored a set of bumper guards for my GMC. Also chrome painted the valve covers cause I had the paint laying around. lol Looks pretty good to me!
Old 05-12-2016, 12:20 AM   #2285
Isaiah92260
Isaiah92260's Avatar
Painted my drivers door jam faw
Isaiah92260 is offline
Old 05-12-2016, 07:32 PM   #2286
LVPhotos
LVPhotos's Avatar
Got IDIDIT chrome plated column in.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats
http://www.cardomain.com/ride/332579...t-c-k-pick-up/
http://67-72chevytrucks.com/vboard/s...d.php?t=560081
LVPhotos is offline
Old 05-12-2016, 08:49 PM   #2287
siggyfreud
siggyfreud's Avatar
Looks good! Mine is on the way from Summit as we speak. Excited to get it. Seem like a quality unit?
siggyfreud is offline
Old 05-12-2016, 08:54 PM   #2288
LVPhotos
LVPhotos's Avatar
Slid into place like a factory fit. Looks like 73 up internals. Of all aftermarket parts I have this is by far the best quality part without a doubt.
LVPhotos is offline
Old 05-12-2016, 10:41 PM   #2289
doobiebro
doobiebro's Avatar
Did you order a universal or the one that calls for your truck? Do you have part #s?
CURRENT & PAST CHEVY TRUCKS
60 C-10 Apache short step side
62 C-10 short step side
66 GMC Long bed fleet side 305 V-6
77 C-20 Custom Deluxe (Blue Goose)
doobiebro is offline
Old 05-14-2016, 08:05 PM   #2290
OldChevy61
OldChevy61's Avatar
Door no 2 epoxied and urethaned.. Hopefully next sat they turn green.
Old 05-14-2016, 11:01 PM   #2291
TJ's Chevy
TJ's Chevy's Avatar
Testing the 572 in our 77 a bit today:
https://www.youtube.com/watch?v=6tPq...vqbdw24exe451k
Old 05-15-2016, 07:21 AM   #2292
Palf70Step is offline
Old 05-15-2016, 09:20 AM   #2293
Backpayne
Dayum!
Old 05-15-2016, 10:24 AM   #2294
ironman3452
ironman3452's Avatar
I opened the engine to see what was not letting it turn
found that 1,7, and number 2 cylinders had white powder in them causing them not let pistons to come up to top of stroke, removed intake, removed heads, , after cleaning them, the motor turns with no problems
now will go and get new gaskets and put her back together, and see if she will run
ironman3452 is offline
Old 05-15-2016, 10:26 AM   #2295
TJ's Chevy
TJ's Chevy's Avatar
Dayum!
Thanks guys!
Old 05-15-2016, 10:30 AM   #2296
LT1 Burb
LT1 Burb's Avatar
Put on my shroud and rad hoses
LT1 Burb is offline
Old 05-15-2016, 10:49 AM   #2297
62 Barnfind
Test fitted the new bed wood before it it goes out to paint.
John Z
62 Barnfind
Old 05-15-2016, 04:42 PM   #2298
Backpayne
Just scored this set of original wheels with rusty trim rings and great condition center caps from a '63. The vehicle has been in one family.
Not bad for $50!
Old 05-15-2016, 06:33 PM   #2299
62 Barnfind
Mocked up the new bed wood before the truck left for paint.
John Z
62 Barnfind
Old 05-15-2016, 07:51 PM   #2300
OldChevy61
OldChevy61's Avatar
Hit the pick n pull this morning for Honda door seals,7.00 each. Jeep door checks,1.99 each ,and a clutch fan for 15.00.. Finished peel n seal on cab floor and behind tank.
Closed Thread
