Old 05-09-2016, 09:54 AM   #1
MattPSU
MattPSU's Avatar
Rear main (crankshaft) seal question
The 5.3L in my C10 has developed an oil leak that seems to be the rear main seal. I need to swap out the torque converter, so now's the time to change out the rear main seal while I've got it that far apart.
My question is, do you need a tool to align everything or not? I keep seeing videos of people using an alignment tool, but I can't find them for sale/rent anywhere.
Also - should I replace just that seal or should I also replace the rear cover seal too?
Any other suggestions/tips/input?
Thanks - Matt
Matt Criswell - Lyman, SC
1972 Chevy Cheyenne SWB - Build: Porterbuilt State 1 Front & Rear, Bolt in Notch, McGaughys 2.5 Drop Spindles, Boyd Welding Fuel Tank
UPSTATE SC GM TRUCK CLUB: FACEBOOK WEBSITE
MattPSU is offline   Reply With Quote
Old 05-09-2016, 12:40 PM   #2
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: Rear main (crankshaft) seal question
This is the guy that makes the kits on LS1tech. I don't think you can rent them.
www.saccitycorvette.com
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 05-10-2016, 11:12 PM   #3
MattPSU
MattPSU's Avatar
Thanks BR3W. Do I need to use a tool? Or can I install it without it?
Matt
Old 05-10-2016, 11:53 PM   #4
ls1nova71
ls1nova71's Avatar
As long as you don't take the rear cover off, you won't need the alignment tool. If you do take the rear cover off then the tool is needed to align it up since it has no aligning tabs made onto it. The tool does make it easier to install the new seal though.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 05-13-2016, 11:29 AM   #5
MattPSU
MattPSU's Avatar
Thanks! That confirms that I thought. I appreciate it sir!
