Old 05-06-2016, 10:51 AM   #1
Afirehawk1
66 C10 New Suspension
any consideration which vendor is better:
Looking at Performance Online, Western Chassis and CPP.
any insight would be great.
thanks Keith
Afirehawk1 is offline   Reply With Quote
Old 05-06-2016, 12:07 PM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: 66 C10 New Suspension
Personally I would stay away from CPP.
Look at the Vendor Reviews section here on the board.
Lots of complaints!
Call one of our board vendors like Pro Performance or use ECE at www.earlyclassic.com.
Keith
Convert to disc brakes.
Old 05-06-2016, 12:08 PM   #3
Afirehawk1
cool, thank you!
Old 05-06-2016, 02:06 PM   #4
The Rocknrod
Moderator
The Rocknrod's Avatar
POL and Western Chassis are owned by the same folks. In fact if you go to the POL store in Carona you can see that and talk to them also (I have).
I have been going with their stuff.
However I did purchase the Early Classic rear panhard bar for my 64 as almost no one else is concerned about the difference in frame mount positions from 65 on.
Old 05-06-2016, 10:20 PM   #5
sandiego65
sandiego65's Avatar
My wife ordered me some parts from POL. Drop blocks, deluxe track bar and 2 piece bolt on c notch. The track bar and finish look great. The c notch I have yet to install but looks quality made and has a nice black finish that came with all the hardware. I am happy with the products delivery was very quick, nothing was missing. The only thing I would have liked is more detailed directions for the notch, but over all I'm happy with the products. Good luck with your build.
sandiego65 is offline   Reply With Quote
Old 05-07-2016, 06:27 PM   #6
Afirehawk1
Hhm. Thanks for the advice. What is a c notch?
Old 05-07-2016, 06:38 PM   #7
OsOdeDIABLO
OsOdeDIABLO's Avatar
I have CPP lowered springs front and rear, CPP c notch, and POL adjustable panard bar and shock relocation brackets. they all work fine. -Jimmy-
NOMADSC.C.
OsOdeDIABLO is offline   Reply With Quote
Old 05-07-2016, 06:40 PM   #8
The Rocknrod
Moderator
Ohhhh William.
Old 05-07-2016, 06:50 PM   #9
C/10 King
C/10 King's Avatar
Originally Posted by The Rocknrod View Post
Ohhhh William.
Hey that's Dr. Zachary Smith!!!!!
C/10 Rene
1966 Short Fleet "The Hag"
1967 CST Short Fleet "Dark Poly"
1971 Short Fleet
1970 Jimmy Custom 2 WD "Golden Ticket"
1972 Blazer 2 WD "Retro Blaze"
C/10 King is offline   Reply With Quote
Old 05-07-2016, 09:18 PM   #10
pedrosc10
pedrosc10's Avatar
I used cpp for my 65 build. Did complete big brake package along with the complete suspension package,trailing arms,shocks,springs. Everything was bolt on. Good quality. Install went flawless. They also have on-line install directions for all the parts they sell. Prices are also low , I shopped around for all the parts. Couple of draw backs . I am in Ill. and it takes a week min to ship from Ca. And make sure you order the right part! They charge a restocking fee.. I think 20%. Other than that they were very helpful during the whole process. I would use them again.
pedrosc10 is offline   Reply With Quote
Old 05-09-2016, 12:41 PM   #11
Afirehawk1
when I order the ball joints and tie rods, I can stick with the stock parts? correct?
Old 05-09-2016, 01:20 PM   #12
zach_carver
zach_carver's Avatar
Ive used CPP and POL and been satisfied with both. Also heard good things about ECE though. I have CPP sway bars with POL control arms and lowering springs and they sent me western chassis shocks with lowering kit. If I order CPP parts I always go thru Summit Racing though to prevent any shipping problems.
1965 C10 LS2/4l70, WHITE, 5/7 DROP
LINK TO SUPER SNOOPY C10 BUILD---> http://67-72chevytrucks.com/vboard/s...d.php?t=689283
1977 C10 SILVERADO HAWAIIAN BLUE, 5/5" DROP, LS6/4L80E
1976 CHEVY K5, 350/350, YUBA GOLD/SADDLE
zach_carver is online now   Reply With Quote
Old 05-09-2016, 05:46 PM   #13
Paul Y
Or you could use Rob at No Limits.
I have his front and rear ARB's and shocks, panhard bar and am very happy with the fit and price. However hsi customer service is beyond reproach.
I was mistakenly sent a pair of incorrect shocks, he sent a replacement pair free of charge including duty and shipping to the UK, and I got them within a few days. No quibble.
P.
Woody's Build -
http://67-72chevytrucks.com/vboard/s...d.php?t=658621
If it goes wrong, I blame the Internet...
Paul Y is offline   Reply With Quote
Old 05-09-2016, 05:52 PM   #14
raic65
raic65's Avatar
I have hotchkis on my truck. Handles like a car now.
raic65 is offline   Reply With Quote
Old 05-09-2016, 06:43 PM   #15
Afirehawk1
Great
Thanks for the info
Any comments on stock ball joints and tie rods ?
Old 05-09-2016, 07:33 PM   #16
lolife99
lolife99's Avatar
Great
Thanks for the info
What are you EXACTLY wanting to do to your suspension.
YES you can use stock tie rods and balljoints as long as they match the spindle you use.
(so in your case,... you would need 63-70 conversion spindles up front if you plan to go to disc brakes)
Are you lowering your truck?
Switching to discs?
Replacing cross shaft bushings on the a-arms?
Idler and pitman arm?
New coils? Drop or stock?
I guess we need more info.
Keith
Old 05-09-2016, 07:43 PM   #17
Afirehawk1
Oh sorry
Thinking 2.5 drop spindles with front disc
Staying with stock BBC front coils. Im using 72 c10 coil since same size. Im installing a 396
Then thinking 4 inch drop rear coils
The 12 bolt rear is already from a 72 but wanting to convert that to disc as well
Wasnt sure what to do next. I did save the center link
Someone had started a front disc standard conversion but im starting from scratch
Old 05-09-2016, 08:35 PM   #18
lolife99
lolife99's Avatar
Oh sorry
63-70 conversion drop spindles will allow you to use all 1966 front end components including all 1966 steering parts.
You really only need your '72 centerlink if you plan to use 71-72 spindles and tie rods, which would require 71-72 balljoints.
What about power steering?
I still like ECE for suspension parts and customer service.
Belltech, Western Chassis, and McGaughy's are great also.
You have a lot on your plate.
Rebuild the entire front end with quality parts.
Do the same with your drop components and brakes.
If you can't afford it, wait until you can.
Keith
Old 05-09-2016, 08:37 PM   #19
TJ's Chevy
TJ's Chevy's Avatar
I got the suspension kit from Classic Parts of America. I'd give it a 4 star.
Old 05-09-2016, 08:44 PM   #20
Afirehawk1
Great
I think i got it figured out now
