small window to big window?
So I'm wondering if there is a way to make the back window bigger. I have the small window, But I am just curious if it could be done.
Re: small window to big window?
Yeah, there are a few people on here that have done the swap. If you do a search you'll likely find a few threads. I think they generally find a donor with a big back window that's otherwise in poor shape to hack up and weld in.
Ahhyeah that makes sense
![]() Join Date: Jun 2011
Hand Made Factory reproduction A/C vents text or call 602-361-6421 Website for A/C vents https://coolc10.com/ |
![]() Join Date: Oct 2009
Jim - how much of a pain was it? Looks like a pretty involved procedure, but the instructions are pretty straightforward. The interior is the area I was most concerned with looking original. Any impressions on the install would be appreciated.
Scott's big window conversion piece is pretty straightforward... cut, weld, grind. As long as you read the instructions and don't rush it... it is pretty much a simple operation.
'65 Tiki Sea 10: http://67-72chevytrucks.com/vboard/s...d.php?t=682356 |
One foot in front of the other
![]() Join Date: Aug 2008
A few threads in the FAQ section about it.
![]() By using a BBW inner panel cut from a donor cab, its possible to do the swap without any visible paint damage. The only welding required would be around the window opening and down each side in the door jamb, then glue the top seam and bottom spot weld area with panel adhesive. The welds are covered by the window seal and door weatherstrips. I love my big window!
* My 63 C10 SWB Fleetside (converted to BBW): http://67-72chevytrucks.com/vboard/s...58#post6851558 @johnny_lamebridge on Instagram ![]() |
I went to Scott's eBay store and did not see the kit. @Daddyoh and @corvettejim where did you order the kit from? I must be missing it..
"Dixie" - 1988 Chevrolet V30 CC DRW "3+3" | 7.4L 454 (L19) | TH400 | 4" lift | 35"s "Lucille" - 1949 Chevrolet 3100 (on hold) |
I just called Scott and he is still very much in business and not a real fan of ebay, and he said anyone is welcome to email him, he's in Great Falls, Mt and is a real nice guy.
mtclassy@yahoo.com |
You can use the form on his web site or, better yet, use the email that is posted above this post... I don't have his number handy but he will get back to you quickly...
