Closed Thread
Old 05-10-2016, 08:17 PM   #3676
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: What did you do to your truck today? Chapter II
Originally Posted by Already Gone View Post
Andy your booster looks looks like it is tight to the firewall. How did you do you that ?
I used the brackets from the 8" booster. It does sit a little closer to the fire wall but not much.
http://www.ebay.com/itm/BLACK-1967-7...item4d3183d855
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Andy4639 is offline
Old 05-11-2016, 06:58 AM   #3677
matthamby
My grandpa made that bumper, he did a good job with it, it did match the "v" in the front end, that is 2"x6"x1/4" channel, pretty solid, but someone has bent that!
matthamby is offline
Old 05-11-2016, 08:08 AM   #3678
jwilb88
jwilb88's Avatar
Mounted my benchwork steering box
jwilb88 is offline
Old 05-13-2016, 01:57 AM   #3679
89AKurt
89AKurt's Avatar
I mounted driving lights (I have a thread about it). Cost $3.49 for stainless allen screws, lights were taken off my dying MINI.
1968 Long Bed
2016 Honda Civic Coupe EX-T ticket magnet
89AKurt is offline
Old 05-13-2016, 08:44 AM   #3680
70STOVEBOLT
70STOVEBOLT's Avatar
I fixed my non-working license plate light on the right side of my step bumper. Replaced the wire and connector on that side (non-factory bumper) and now it works! Also swapped out my faded side markers for new aftermarket units.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast"
200,000 Mile Club
Disc Brake Club
Owner installed options:
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Sliding Rear Window
Power Windows
Power Locks
Sniper EFI
2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear
70STOVEBOLT is offline
Old 05-13-2016, 01:52 PM   #3681
summitflier
summitflier's Avatar
I stained the bed... (I don't usually brag about that, but... )
68 C10 SSB 383
12 Charger 6.4L
12 Accord 3.5L (Wife's ride)
05 Ram 1500 5.7L
My build thread - http://67-72chevytrucks.com/vboard/s...d.php?t=676545
summitflier is offline
Old 05-13-2016, 02:21 PM   #3682
BugzC10
BugzC10's Avatar
Nice deep color..what are you going to do next? Spar?
1970 C10 Short Stepper with 71/72 front clip.
BugzC10 is offline
Old 05-13-2016, 02:40 PM   #3683
summitflier
Thanks - Minwax Red oak.
Trying to decide between spar varnish, or a few people have recommended
exterior urethane. Anyone have any experience either way?
Other than clear... any certain type? Satin, gloss?
68 C10 SSB 383
12 Charger 6.4L
05 Ram 1500 5.7L
Old 05-13-2016, 03:03 PM   #3684
BugzC10
BugzC10's Avatar
I used Minwax Polyurathane clear satin. 4 or 5 coats... It's been a couple years and holding up great. The truck is always garaged, however.
BugzC10 is offline
Old 05-13-2016, 03:19 PM   #3685
summitflier
Looks great. Someone recommended Minwax Helmsman Spar Urethane, clear gloss.
I think I'm going to give it a try. 4 or 5 coats sounds about right.
68 C10 SSB 383
12 Charger 6.4L
05 Ram 1500 5.7L
Old 05-13-2016, 03:25 PM   #3686
BugzC10
BugzC10's Avatar
Now that you wrote it out..that's exactly what I used. Hey..I'm over 65, I get a pass now and then. I looked in my garage and found the poly satin, but I had a feeling that it was not what I used.
BugzC10 is offline
Old 05-13-2016, 07:52 PM   #3687
CST10
CST10's Avatar
Changed the water pump gasket and water neck gasket on the ol 250 in goldilocks. They had a slight seepage.
MyToys:
Goldilocks the "Ol School Survivor" 1968 C10, SWB Stepside, 08/15 TOTM, 250 CI 6 cylinder, 3 on the tree, 3.73 rear, 3/5 static drop, 23,500 original miles.
Samson the 1970 CST10, LWB, 462Ci, Turbo 350 tranny, 3.08 rear gear, PB, PS, A/C, AM/FM, 2/4 Drop.
Brutus the 1998 Camaro Z28, 33,500 original miles, LS1, 519 RWHP/497 RWTQ.
Member of the Louisiana Classic Truck Club, LCTC
Member of the Louisiana C10 Club
Member of the Baton Rouge Drifters Car Club
CST10 is offline
Old 05-13-2016, 09:51 PM   #3688
69chevytrucker
69chevytrucker's Avatar
put a gas peddle in my project super short c10 4x4
69chevytrucker is offline
Old 05-13-2016, 11:09 PM   #3689
projectking
projectking's Avatar
Pulled my engine outside in the rain.
68 GMC C3500 Longhorn DRW
67 Chevy C10 LWB
90 Mustang Gt
90 Mustang Notchback
projectking is offline
Old 05-14-2016, 06:55 PM   #3690
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
Sometimes I have to pinch myself after having removed parts. 45 years on the truck and better than new. Personally, I like some stain in the mirror. I'll hit the chrome one last time before I mount this in 2018, just because. By the image, I did a sloppy job on that boot. I should have drenched it in treatment and used a toothbrush religiously. My eyes failed me, followed by me brain. EDIT: That was a stand in, I took a pic. of the right one:
BTW, 3M chrome/metal polish is great stuff.
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline
Old 05-14-2016, 07:27 PM   #3691
BugzC10
BugzC10's Avatar
That look brand new....did you use a power tool or by hand?
BugzC10 is offline
Old 05-14-2016, 08:57 PM   #3692
firedemon
replaced my windshield gasket with a precision gasket don't buy the lmc gasket that thing leaked so bad and I couldn't get the trim in to save my life . the new one I bought dosent have the trim and I'm glad I was able to put it in in 20 min with just my brother for help pouring rain here today and leak free
firedemon is offline
Old 05-14-2016, 10:04 PM   #3693
71CHEVYSHORTBED402
Personally I don't use LMC. I know they have a few nice pieces though, like their top end instrument cluster. Precision seems to have a good reputation. A competitive vendor recommends them to restore vent windows.
Tony
Old 05-14-2016, 10:15 PM   #3694
71CHEVYSHORTBED402
By hand. I hit it 3-4 times with a flat hand, polish and a layer or two of small terry cloths. These rub out rather well. Removed a nice layer of black, possibly tarnish. That may have worked out to be a good thing......I didn't expect this at all. The rubber is great as well. Pleasantly surprised to say the least. Especially after handling the mirror far too often, because the arm was stripped where the mirror attaches. I had different priorities.
Note: That polish does rub out fine scratches in chrome, which may vary on piece (I'm no expert). Removes light scuffs as well.
Tony
Old 05-14-2016, 10:50 PM   #3695
firedemon
I thought a gasket is a gasket with a 30 dollar difference went the wrong way learned a lesson
Old 05-15-2016, 02:48 PM   #3696
Ed F
Ed F's Avatar
The Highlander's water pump was making noise and seeping a bit, the timing chain cover was dripping oil and the radiator was dripping antifreeze out of soft spots on the drivers side tank. So I pulled it all apart yesterday afternoon and put it back together this morning. I couldn't believe the number of loose bolts I found. Basically if it wasn't a bolt for belt adjustment it was slightly more than finger tight. It makes me wonder about the internals. I also found a freeze plug that was seeping so I replaced that too. The belts are in great shape and so is the upper radiator hose but the lower hose is pretty soft and the spring inside is badly corroded and a piece bike off. Are the radiators hoses readily available?
Ed F is offline
Old 05-15-2016, 04:29 PM   #3697
firedemon
checked still getting drips on floor near clutch pedal but dash is dry as a bone think I have another issue never ends
Old 05-15-2016, 06:24 PM   #3698
69chevytrucker
got my 4x4 shifter and trans shifter bolted up today, took the hump from a1983 k5 blazer and cut out about 4 inches of the length out and welded it back together so it would fit on the floor.
Old 05-15-2016, 07:07 PM   #3699
BenC/10
Spent today trying to figure out why my seat felt so "lumpy"...Answer found! looks like the perimeter frame has broken off on the driver side, two of the flat looking springs are loose at the coiled end,one has been replace by simple wire, and the side support springs are broken on the passenger side
BenC/10 is offline
Old 05-15-2016, 07:22 PM   #3700
OregonNed
OregonNed's Avatar
We are just now doing my bed and looking at about 10 coats of this:
https://www.epifanes.com/page/clear-finishes
Really good stuff...
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop
OregonNed is offline
Closed Thread
