Old 05-13-2016, 04:55 PM   #1
michael bustamante
michael bustamante's Avatar
OEM fuel line question...
Pulling the 5.3 motor out of the Yukon today 2003, should I try to use the OEM lines for my conversion to the 67 or just build new lines? Or just use some of the oem lines like the ones leading to the fuel rail. I'm having a hell of a time releasing the top fuel line to the rail and thinking ibshould just cut it but if I can use the OEM, ID rather do that
1967custom
michael bustamante is offline   Reply With Quote
Old 05-13-2016, 05:47 PM   #2
mongocanfly
mongocanfly's Avatar
Re: OEM fuel line question...
It will be much easier on you to just run new lines than trying to make the factory ones work. The oem ones are formed to fit that truck and its doubtful they would work on your 67.I used steel braid on mine.
Old 05-13-2016, 06:13 PM   #3
michael bustamante
Yeah i was thinking that too. I got the dang fuel line off finally! I was going to try to use the factory pump also but I just bought the wrangler tank set up instead. So custom lines willake more sense
1967custom
Old 05-13-2016, 06:17 PM   #4
mongocanfly
Yeah I had a heck of a time getting mine off to..wound up cutting/mangling them off with some side cutters..
Old 05-13-2016, 07:07 PM   #5
ls1nova71
ls1nova71's Avatar
I always use the lines that run down the back of the engine and to the transmission, then cut them off there and make new ones from there to the frame.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 05-13-2016, 08:47 PM   #6
michael bustamante
Ok that's what I'll do too
1967custom
Old 05-13-2016, 11:32 PM   #7
NurseBen
NurseBen's Avatar
I did what ls1nova71 said. I'm still doing my swap but am going with the nylon? line with all the factory push on fittings from my donor vehicle as well as the sending unit/pump. I cut around the donor vehicles gas tank lock ring and bolted/gasket to a 80 something blazer.
NurseBen is offline   Reply With Quote
Old 05-14-2016, 09:19 AM   #8
65standard
65standard's Avatar
I did what ls1nova71 did too. Saves time and money.
Here is my fuel system build thread.
http://67-72chevytrucks.com/vboard/s...d.php?t=703032
Tony Nicholas @ Midwest Metal Masters
1953 Chevy 3100 392 Hemi w/727 & 9” Ford
1985 Chevy C/10 6.0L 4L80 373 locker
65standard is offline   Reply With Quote
Old 05-14-2016, 01:45 PM   #9
michael bustamante
65standard. thanks for the link. im going to keep this page up for easy access for when im ready to lay the lines!
1967custom
Old 05-15-2016, 12:21 PM   #10
Tork?
That seems like the smartest thing to do. Do the OEM lines over the trans terminate in a quick connect or will they need to be cut and flared?
EDIT: just looked at 65standard's thread and it looks like he cut and flared the original lines with a compression fitting for a push connect to nylon lines. Slick setup
Tork? is offline   Reply With Quote
Old 05-15-2016, 08:10 PM   #11
65standard
65standard's Avatar
I cut the factory LS fuel lines right before they changed into nylon. Then added my own new nylon lines with compression fittings from steel to nylon.
Old 05-16-2016, 06:52 PM   #12
uxdesigner
I did the exact same thing, it's a common solution only I used Russell's cloth-braided ProClassic hose with AN fittings instead of nylon.
uxdesigner is offline   Reply With Quote
