Old 05-13-2016, 11:11 AM   #1
scott657
scott657's Avatar
Radiator
Gang, I am planning a V8 swap into my 63 C10
The stock radiator is 21-5/8 wide X 22 tall. I would like to go with an aluminum radiator and I understand the Champion 2 rows are good pieces. I have used these to cool 2 mild v8s before. Has anyone got one of these with the stated dimensions? If so how about a part #. The ones on ebay give quite a larger configuration.
Also if there is another size that will fit with or without modifications I don't have a problem with that either.
As always, Thank You
Scott
63 C10 Stepside
230 1bbl
Saginaw 3 spd
scott657 is offline   Reply With Quote
Old 05-13-2016, 04:35 PM   #2
forestb
forestb's Avatar
Re: Radiator
I got a Us Radiator for my 62 and it fit great. Bolted right up. I hangs down a little lower than stock but I don't think that will be a problem. You can find the part numbers on there web sight.
forestb is offline   Reply With Quote
Old 05-13-2016, 06:16 PM   #3
WOLFMANmike
WOLFMANmike's Avatar
Re: Radiator
here ya go hope this helps ya http://www.championradiators.com/Che...radiator-63-66
WOLFMANmike is offline   Reply With Quote
Old 05-13-2016, 06:29 PM   #4
scott657
scott657's Avatar
Re: Radiator
Originally Posted by WOLFMANmike View Post
You are the man!!!
Scott
63 C10 Stepside
230 1bbl
Saginaw 3 spd
Old 05-13-2016, 06:31 PM   #5
WOLFMANmike
Re: Radiator
You are the man!!!
Glad to help brother .... Happy Truckin
Old 06-05-2016, 11:11 AM   #6
SparkyRnD
SparkyRnD's Avatar
Re: Radiator
If you are still looking, we hand-make aluminum radiators here in the USA using domestically sourced materials, and no plastic / epoxy / glue is ever used. And, we are a site sponsor here:
http://67-72chevytrucks.com/vboard/s...d.php?t=591690
www.RnDFabrication.com
Custom Radiators, Valve Covers and Overflow Tanks
SparkyRnD is offline   Reply With Quote
Old 06-05-2016, 07:58 PM   #7
Hugh in NC
Hugh in NC's Avatar
Re: Radiator
I just installed an American Eagle by Champion. It has 1 inch tubes instead of 3/4 inch of the standard Champion. I got mine from jegs. $200.95 and free shipping.
http://www.jegs.com/webapp/wcs/store...Term=166-AE284
Hugh in NC is offline   Reply With Quote
Old 06-05-2016, 08:31 PM   #8
Rickysnickers
Rickysnickers's Avatar
Re: Radiator
I have a Champion in my '57. The only complaint I have about is that the mounting tab (the length of the radiator), is such that the radiator does not sit flat against the core support. It protrudes into the engine by about an 1" or so. With the electric fan on it, it comes really close to the water pump pulley and I have a short pump on the engine.
