Future Owner
installed some NGK spark plugs on my 350. When i installed my new ACCEL wires with straight boots it feels like it is loose on the spark plug like the connector part on the spark plug is to small or something...are there diffrent size spark plug connectors on wires or on the spark plug itself. I havent stried to start it yet or anything i was just curious if this was common??
Its not the end result that counts most...its the journey along the way that's most rewarding My truck doesn't leak, it just marks it's territory |
all the terminal ende are the same on spark plugs. Either the end is loose(common) it will wiggle or you don't have them all the way on. Some are a real pain in the butt to get snapped on, my accel wires are the same way, difficult to get on all the way.
64 Panel Rebuild Pics Clutch Replacement and Borg Warner T10 Trans Rebuild 64 Panel 1/2 Ton 350cubes/400hp BorgWarner t-10 3:73 Auburn Posi |
Future Owner
thanks for the info.......
