Old 05-15-2016, 01:31 PM   #1176
Valarius_Starchaser
Valarius_Starchaser's Avatar
Re: 48 Burb, bagged, 5.3, 20 year wait
Wow those do look really slick Doug I will need to track a set down for my future exhaust setup for sure
"Orange Crush"
Valarius_Starchaser is offline   Reply With Quote
Old 05-15-2016, 01:40 PM   #1177
RockinKees
RockinKees's Avatar
You're a handy guy Doug!!
Exhaust is going to look great!
Nice clamp, never saw those before unfortunalty....
Cheers!! Kees.
1959 Chevy Fleetside Longbed
My build: http://67-72chevytrucks.com/vboard/s...d.php?t=643426
Kool Guyz CC
Instagram: _King_Kustom_
RockinKees is offline   Reply With Quote
Old 05-16-2016, 05:37 PM   #1178
lower50's
lower50's's Avatar
Nice looking exhaust. I'm not sure but I think your exhaust hanger might catch fire.
http://67-72chevytrucks.com/vboard/s...d.php?t=648459
https://67-72chevytrucks.com/vboard/...d.php?t=769441
1951 MG TD
1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers.
1952 GMC 9700 p/u 7.3L diesel on air, dually
lower50's is offline   Reply With Quote
Old 05-16-2016, 08:20 PM   #1179
Advanced Design
Advanced Design's Avatar
Here you go VS...Strong hand Tools PG114V Pipe Pliers with Large... Strong hand Tools PG114V Pipe Pliers with Large...
Thanks Kees! Me handy? From the man who has custom built about everything on his truck that means a lot to me!
Thanks Lower, that's not a hanger, it is an exhaust splash shield..
Mufflers are on order from Jegs....thinking the run might get too long to make the 90 turn to the outlet. Canning the X would simplify this, though am going to try to fab it out to fit.
Advanced Design is offline   Reply With Quote
Old 05-17-2016, 08:36 AM   #1180
BIGglaSS
BIGglaSS's Avatar
Thanks! They're 22.97 at Summit. Definitely going to throw them in my cart on the next order.
BIGglaSS is offline   Reply With Quote
Old 05-20-2016, 12:14 AM   #1181
CHIZZLER
SAVING ONE TRUCK AT A TIME
CHIZZLER's Avatar
Progress is looking great.
53-suburban (99% done)
40-pick up (99.9% done)
12-cc lb dually D-max (dd)
61-crew cab D-max
"PAY LESS FOR WHAT YOU NEED PAY MORE FOR WHAT YOU WANT"
53 BURBAN BARN FIND:http://67-72chevytrucks.com/vboard/s...d.php?t=404091
1940 PROJECT MOON SHINE:http://67-72chevytrucks.com/vboard/s...d.php?t=551088
1961 CREW MAX: http://67-72chevytrucks.com/vboard/s....php?p=6957999
CHIZZLER is offline   Reply With Quote
Old 05-20-2016, 08:25 AM   #1182
Advanced Design
Good deal Big. It pays to shop around.
Thanks Chizzler. Kinda slow though some progress.
The mufflers came in and hope to see about fitting them up tomorrow.
Spring here has been so wet there has been zero planting done. One of my neighbors has his equipment ready to go as soon as the fields dry up enough for working.
Iowaboynca, I took this pic just for you.
Old 05-20-2016, 11:11 AM   #1183
joedoh
joedoh's Avatar
great detail work!
can you tolerate an H pipe or are you specifically looking for the x pipe sound? I have read an x pipe makes more hp at high rpm and the h more torque at low rpms. there is a big difference in sound too, the x is more raucous and unrestrained.
here is a great comparison, apple to apple, same car with same mufflers and differing only in x and h pipe.
Old 05-20-2016, 06:39 PM   #1184
Advanced Design
Thanks joedoh. The 56 has the X pipe and I like the sound. Even though there will be variance on the Burb with much shorter pipes after the mufflers, I am looking to somewhat duplicate the sound.
An H pipe is next up if the X doesn't work out.
Old 05-22-2016, 08:31 PM   #1185
Advanced Design
OK, the X pipe set up fits.
The patent pending exhaust support system was moved back to support muffler placement.
Welder series header collector flanges were used to connect the exhaust tip and flex pipe. Same for the 90 muffler exit pipe to the other end of the flex pipe. Thanks again to Bob and Marc for the flex pipe suggestion!
One of the pics shows layout to determine where to cut the 90. And I forgot to include the flange thickness, so I had to cut it again.
Right side is positioned and tacked together. Somehow I didn't order enough flanges, so hopefully they will be here this week. Then I can finish the left side.
Once finalized, some of the connections will be welded and some secured with band clamps to facilitate any future removal. Then a couple hangers and it should be good to go.
Old 05-22-2016, 09:53 PM   #1186
youngrodder
youngrodder's Avatar
Doug
The exhaust looks fantastic...Nice work. Hey in looking at your pics you might want to add a flex joint closer to the headers. I added mine after I noticed I was getting welds breaking from stress cause by movement. My exhaust system in the 48 is all SS and SS can act weird when heated and cooled. I actually have my tips with a rigid mount. I tied to have them with movement like yours but my tips would bang against the opening in the running boards. especially because like you I kept the tip opening as small as possible.
Just my 2 cents, you know what your doing.
Marc
…………...........__________
.................. ((__|__||___\____
..;.;;.:;:;.,;..;((_(O))____ (_(O))
1948 Chevy Truck - Finished SOLD!!
1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021
http://67-72chevytrucks.com/vboard/s...d.php?t=605484
1994 4x4 Blazer - "Field Find"
https://67-72chevytrucks.com/vboard/...ferrerid=30857
youngrodder is offline   Reply With Quote
Old 05-22-2016, 10:01 PM   #1187
Coach529
Coach529's Avatar
Looks great Doug. Giving me ideas!! Love it!!
1949 Chevy 3600
"Adventures of Henry"
http://smu.gs/QOlhWY
Coach529 is offline   Reply With Quote
Old 05-22-2016, 10:22 PM   #1188
Advanced Design
Thanks Marc and Coach! Me know what I am doing? Naw, making it up as I go and using what I learn here...and I am always way open for advice and suggestions.
Marc, the tips are bolted solid in the mounts in the running board. The rest of the system from mufflers forward is the same as I used in the 56 and it hasn't had a problem with cracking. Could be because the Pypes is 409 stainless rather than the 303? Appreciate the heads up!
Here is a pic of a really nice one I found today in a thread. this one is a lot cleaner installation than mine.
Old 05-23-2016, 12:16 AM   #1189
joedoh
joedoh's Avatar
way to go idaho!
Old 05-23-2016, 09:51 AM   #1190
reaper71
reaper71's Avatar
Looking good Doug..
For future reference Speedway has flanges for around $6 each (nothing wrong with Hortons stuff Ive used his stuff in the past, very nice quality) Speedway you usually get the next day and you can get the gaskets from them as well.
A bit less money and time to get the parts (My 2 cents)
Mark...
reaper71 is offline   Reply With Quote
Old 05-23-2016, 06:06 PM   #1191
Advanced Design
Originally Posted by joedoh View Post
way to go idaho!
Thanks joe...made me
Originally Posted by reaper71 View Post
Looking good Doug..
Mark...
Thanks Mark. I didn't think of Speedway and I've gotten good parts there on your suggestions before. I should have thought of them.....and they need to send you referral checks. Always really appreciate suggestions.
Old 05-23-2016, 10:03 PM   #1192
youngrodder
Doug
The funny thing is this was my exhaust version 1.0
In 2.0 I added a small SS brace that bolts to the running board mount to keep the exhaust tip from rattling against the running board.
In version 3.0 I added flex joints and I changed the flanges on my exhaust to better match my headers. Third times a charm.
Marc
Old 05-24-2016, 07:59 AM   #1193
RockinKees
RockinKees's Avatar
Exhaust is looking really good!
Don't see something wrong with it?
I like that place for an outlet.
Cheers!! Kees.
Kool Guyz CC
Old 05-24-2016, 08:01 AM   #1194
lower50's
lower50's's Avatar
Nice job Doug you got all that to fit together really nice in such a tight place. I cant wait to hear how it sounds. It took some time but I really like your under running board exhaust. Nice touch.
1951 MG TD
Old 05-28-2016, 01:25 AM   #1195
55 Chevy Dave
55 Chevy Dave's Avatar
Hey Doug.
I was finally able to make it through all 48 pages of your thread. What a great build! You've done a lot of great work!
Your exhaust looks great! I am starting mine tomorrow and hope it comes out as good as yours did.
Thanks for spending all the time to document what you have been up to.
Dave
My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=654899
55 Chevy Dave is offline   Reply With Quote
Old 05-28-2016, 10:48 PM   #1196
Advanced Design
Originally Posted by youngrodder View Post
Doug
Marc
Sometimes it takes a few revisions. Hope my 1.0 works!
Thanks Kees! It might need a flex pipe between the down pipe and the X. I am going to give it a shot this way so if there are problems with cracking, Marc can say "I told you so!"
Thanks Lowers, I think I got lucky that it fit.
Originally Posted by 55 Chevy Dave View Post
Hey Doug.
Dave
Hey thanks Dave! Glad you were able to get through it. It does take time to update these threads...way more than on FB. With your fab skills I am certain your exhaust will be awesome!
OK, it won't win a Riddler award, though it should be good enough for this old Burb.
I don't like the regular style exhaust clamps and yet need to use them on the muffler as the exhaust bends too close to it to use a band.
There are exhaust bands at the slip joint behind the downpipe extensions to make disassembly easier. The butt weld at the down pipe to the extension and the slip joints going into the X pipe will be welded. And the flanges at the flex pipes need welding too.
Old 05-29-2016, 09:08 AM   #1197
youngrodder
Looks great Doug, this should work....
I need to get my x member out to of the attic that I had made for the 48 and see if I can use it for the Suburban...Something tells me it wont but I'm due for a break soon....
Marc
Old 06-05-2016, 08:38 PM   #1198
Advanced Design
Marc
I bet it will fit like a glove! If it won't work Marc, maybe the Pypes X I used might fit.
Just a side note, the 35 Master coupe I sold just over a year ago is on the road. Owner texted me this. I told him I changed my mind and would gladly refund his money.
Old 06-05-2016, 08:45 PM   #1199
Advanced Design
So once the exhaust was done I threw the body back on the frame to make sure the tank brackets would fit. Yes, the tank filler pipe will have enough room.
Notice the new shop rollers? The uni-lugs were ugly and a pita to put on.
Old 06-05-2016, 08:47 PM   #1200
Advanced Design
Loaded up...
