Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1967 - 1972 Chevy/GMC Suburbans & Panels Message Board > 1967 - 1972 Chevy/GMC Suburbans and PanelsProjects and Builds
Old 05-16-2016, 02:14 PM   #1426
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Re: 1969 SuperBurb build-up (Bagged and Blown!)
Nice work! I really like the tail light conversion on it!
Ryan
1969 Chevy milk truck
Old 06-07-2016, 08:26 AM   #1427
Hart_Rod
Hart_Rod's Avatar
Thanks Diesel!
No picture worthy updates but I am making progress. I've got most of the engine compartment wiring completed, just need to finish up a few things. I was able to power up the PCM and pull the factory tune, so I can play with that on rainy days, . I also checked the DBW pedal and it seems to activated the throttle body correctly, .
I also started installing the Fatmat installation, considering how large this beasts is, that's going to be a job! The interior wiring is about 50% done, I'm just waiting on my gauges.
No one really notices all the small detail stuff and it's what takes the most time!
Hart_Rod is offline   Reply With Quote
Old 06-07-2016, 11:51 AM   #1428
smbrouss70
smbrouss70's Avatar
I am eagerly waiting to see what your gauges look like!
Steven
"If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers
R.I.P. Oscar
R.I.P. Ratchet
1967 Pontiac GTO - Dad was the Original Owner
1970 Chevy 2wd SWB "Oscar's Truck"
1970 Chevy 2wd Blazer "Ratchet's Blazer"
2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar"
2017 Chevy Suburban "BDB"
2020 Chevy Blazer Premier "Foxy"
Shop Build
smbrouss70 is offline   Reply With Quote
Old 06-07-2016, 06:11 PM   #1429
Amen to that!.
I am so glad to see the burb being the main project and close to being roadworthy again! Looks great Rob.
Old 06-08-2016, 08:16 PM   #1430
Riveted1
Tasty Cakes!
Riveted1's Avatar
FWIW, you only need to cover 25% of the panels with FatMat. Focus on the center of large panels. After that point, the benefits are minimal. Might save you some time and you can use the remnants for another project.
I'm a little and a lot
Ground beef: A cow with no legs.
'66 Chevy SWB "Penny"
'67 Chevy Big Window SWB- aka "Pearl"
'72 Burb- "Betty" "It's not a hearse dammit"
'99 Chevy Ext. cab Silverado
Riveted1 is offline   Reply With Quote
Old 06-10-2016, 03:02 PM   #1431
Hart_Rod
Hart_Rod's Avatar
Here's sneak peek....
Amen to that!.
Thanks Bill! I'm plugging away on it. I don't have a projected date to finish it, I just try to get a little done each week.
Interesting, I had never heard that before. Is that just for sound? heat? Or both?
Old 06-10-2016, 03:36 PM   #1432
smbrouss70
smbrouss70's Avatar
I'm lovin' it! I wonder if they are going to offer them after your set like they did with the ones you had in the Farm Truck?
Steven
R.I.P. Oscar
R.I.P. Ratchet
Shop Build
Old 06-10-2016, 03:47 PM   #1433
Hart_Rod
Hart_Rod's Avatar
My guess would be yes....
Old 06-10-2016, 04:17 PM   #1434
smbrouss70
smbrouss70's Avatar
DD may just earn the right to be at the top of my list again if they do.
You should get a commission from them, since you get them to make what everybody wants.
Steven
R.I.P. Oscar
R.I.P. Ratchet
Shop Build
Old 06-10-2016, 06:49 PM   #1435
Riveted1
Tasty Cakes!
Riveted1's Avatar
Panel resonance. That's all constrained layer dampening products are made for. They are designed to add mass to the panel to lower its resonant frequency. If you cover every panel with a CLD that has an aluminum layer, you will see SOME insulating properties, but it's an inefficient way of doing things. For a greater reduction of temperatures in the vehicle, you'd want to use a thermal barrier.
IF you want to get that luxury car tomb-like feel, you'll want to use closed cell foam over the CLD followed by a layer of mass-loaded vinyl. The CCF will isolate the MLV from the vehicle, and the MLV is what blocks out the noise.
Old 06-11-2016, 05:53 AM   #1436
gringoloco
A guy with a truck
gringoloco's Avatar
What goes in the middle? Please say not a clock
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 06-12-2016, 04:04 PM   #1437
smbrouss70
smbrouss70's Avatar
Looks like a third digital display with the 3 buttons. It just has the markings like a non-tach cluster instead of being just black, right Rob?
Steven
R.I.P. Oscar
R.I.P. Ratchet
Shop Build
Old 06-13-2016, 06:47 PM   #1438
Hart_Rod
Hart_Rod's Avatar
Thanks! Where do you get the closed cell foam?
Nope!
That's correct!
Old 06-14-2016, 10:53 AM   #1439
gringoloco
A guy with a truck
gringoloco's Avatar
Dig it! You're gonna end up costing me money
-Chris
Old 06-14-2016, 06:05 PM   #1440
Riveted1
Tasty Cakes!
Riveted1's Avatar
Don at SDS has great products and they are specifically made for automobiles. There is also a lot of great info on his site. https://www.sounddeadenershowdown.co...-cell-foam-ccf
Some people have been happy with generic foam. (1/8") http://www.thefoamfactory.com/closed...ticrubber.html
Others have used yoga mats. Just make sure they're closed cell foam so they don't retain moisture.
There are probably some CCF/MLV combination products out there, but I don't know who's making them these days. (I know Second Skin used to have Luxury Liner Pro, but I think they're out of business.)
Old 06-16-2016, 11:23 AM   #1441
Hart_Rod
Hart_Rod's Avatar
Thanks for the links! The entire underside of my suburban is covered in Line-X. How much do you think that will aid in noise reduction?
Old 06-16-2016, 07:23 PM   #1442
72MARIO
72MARIO's Avatar
I want those gauges for my ls swap. Any idea what it will take to get cluster like that ?
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 06-16-2016, 07:32 PM   #1443
Riveted1
Tasty Cakes!
Riveted1's Avatar
I'm not sure. The only vehicles I've been in that had the full line-x treatment underneath were 4x4's w/big tires.
I bet it does help, but without taking measurements before and after, I'd just be guessing at how much improvement you'll see w/the Line-X. It will increase the mass of the panels (which is the purpose of the CLD,) but the floors are pretty rigid compared to other areas of these burbs. The places that are really bad resonance-wise are the big panels; the hood, roof, rear sides and doors. It might also help by reducing road noise coming through the wheel wells. I'd be surprised if it didn't give you some thermal protection from the engine/exhaust, too.
With that said, most of those would probably just be bonuses to the protection it gives the vehicle. If you REALLY want it quiet like a new luxury car, you need to get the purpose-designed stuff, IMO.
Old 06-17-2016, 09:13 AM   #1444
Hart_Rod
Hart_Rod's Avatar
Dakota Digital should be have it listed as a product within the next 3-6 months.
Thanks again for the info, I'll look into the engineered stuff.
Old 07-05-2016, 10:02 AM   #1445
Hart_Rod
Hart_Rod's Avatar
Trying to get my boy ready for college this fall so progress has been slow. Still working on integrating all of the wiring harnesses while trying to making them look neat and clean. Hopefully I'm not to far away from a light off.
On a different note, I'm trying to decide if I want to go with 72 style door panels or the early style 69-71. I've tried to keep somewhat true to the "Cheyenne Super" look, but can't decide on this part. Plus, I'm not sure how hard it's going to be to track down the panels. Thoughts or suggestions?
Old 07-05-2016, 10:12 AM   #1446
smbrouss70
smbrouss70's Avatar
72 panels are difficult to find in decent condition, and the re-pops are junk. Your Burb is a 69, so I would go with the 69 only door panels which you can get a decent re-pop in that style.
Steven
R.I.P. Oscar
R.I.P. Ratchet
Shop Build
Old 07-05-2016, 12:53 PM   #1447
Hart_Rod
Hart_Rod's Avatar
It's a 69, but I'm running a 72 grill and bumper, . I guess I'll look around for some 72 stuff before I make my decision.
Old 07-05-2016, 10:40 PM   #1448
gringoloco
A guy with a truck
gringoloco's Avatar
Or run a 69/70 grille/bumper. They're sexy, just sayin
-Chris
Old 07-07-2016, 09:10 AM   #1449
Hart_Rod
Hart_Rod's Avatar
, I hear you, but I've already spent a bunch of $$$$ on a new 72 grille, bumper and light setup, .
Old 07-13-2016, 08:08 AM   #1450
Hart_Rod
Hart_Rod's Avatar
Ok, well I have been making progress, (the wiring is nearly done), but I have run into a couple of setbacks that will take about 3 weeks to overcome. Also I made another change that will slow me down somewhat until the new part comes in (late August, early September), so this saga continues......
