#3701 |
RAT1968 '68 Cab/'71 Parts
Re: What did you do to your truck today? Chapter II
M17 Coarsegold, CA RAT's shiny now. But always a rat. |
#3702 | |
#3703 |
I looked at it again ;
I RETIRED (yippee) Friday after 32 years of eating bovine excrement and now I'll have some time to hopefully get back to it.... Reading and looking at all the good hard works you alls do is motivating me
-Nate Geezer '49 3100 235 W/ Muncie SM420 SOLD '69 C/10 shortbed sidemount survivor 250 L6 W/ 350TH ![]() |
#3704 |
![]() Join Date: Oct 2015
#3705 |
I painted the inside today! I am pretty excited.
#3706 |
Had some pics taken today for classic truck magazine
#3707 |
[QUOTE=PaddyO2053;7595561]Had some pics taken today for classic truck magazine Attachment 1533723[/QUOT
Great looking truck |
#3708 |
I finished mechanical repairs ,one wheel bearing ,speedi sleeve for seal ,paint rotors ,now im waiting patiently for body shop to finish box and paint this thing so I can carry on with assembly
#3709 |
Dimpled my door panels over the weekend.
#3710 |
Congrats nate im sure its been a long time coming.
Finished smoothing and painting set of rams for my k. What a dirty job that iron dust is nasty stuff. I still gotta terminate the wires at the cap and get a new clutch but besides that the 400ci is ready to drop in. now to get the truck ready for it...scrape clean and paint another dirty job. I don't think I'll be reusing this brake line banjo bolt...looks like it's trying to set me up for a bad evening. Also made a oil primer out of a old distributor. I was thinking of mounting a extra oil pressure Guage to it.
81 camaro 355 4/spd 342 posi my first love ![]() 67 swb step 454/4spd ott 373 posi 4/7 drop. 2000 s10 zr2 little blue truck that never gets stuck. '74 heald super bronc vt8. tecumseh powered moon rover. |
#3711 | |
1967 C10 SWB Small Window |
#3712 |
Thanx Blues ~ 32 years of eating you know what.....
![]() Gotta get my truck road worthy again . Your engine really looks sharp ~ I'm sure many here would enjoy seeing the details up close and personal along with descriptions ~ I too am fanatical about how I dress engines and assemble things , I'm no painted but I really enjoy the details . Did you wire brush those manifolds or what ? they're aftermarket or you ground them smooth ? . NAPA sells them brandy new , Chinese I *think* .
#3713 |
Installing some HEI tune up parts when I get home from work. I've replaced everything on this HEI except for the coil, so I might as well replace that too....
1965 Malibu SS L79 Restoration Page 1965 Two-Door Wagon Project Progress Page 2006 Pontiac GTO Preservation Project Rich Cummings |
#3714 |
#3715 |
#3716 |
That's sweet...that must of cost a chunk of change. Was it cheaper than having it professionally polished? I inquired about polishing mine polished and they wanted $600 bucks....so I passed and cleaned up myself, but it still looks so so.
1970 C10 Short Stepper with 71/72 front clip. |
#3717 |
![]() Join Date: May 2012
congrats on the retirement ......its great , best job I ever had . hope you have as much fun as ive have , hope the truck is coming along good .....Don
#3718 | |
It was $800 to chrome it and with a lifetime warranty.. Most shops would only give me the tail light warranty when it came to chroming a aluminum grill |
#3719 |
I masked all of the turn signal switch and upper shaft. I left the tilt lever on there and just masked it so I could adjust the tilt while painting to get complete coverage.
#3720 |
![]() ![]() Join Date: Feb 2009
rsgt..........Don't know what color that is, but I'd be excited too.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly guide (kit) for restoring this truck from the ground up, complete with details including full hardware descriptions. Much of the info. applies to all 67-72 GM. My build thread, with some info. about the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
#3721 | |
I'm out December 31st...........I'll be working on my truck, and then I'm going to work on my truck. And then I'm going to stare at it.
#3722 |
[QUOTE=VWNate1;7597243]Thanx Blues ~ 32 years of eating you know what..... and after all those meals I still wouldn't say your full of $hit.
Did you wire brush those manifolds or what ? they're aftermarket or you ground them smooth ? . In my first pic I included the tools I used to smooth them. These are oe manifolds i have a few layin around so i figured i could ruin a set. ![]() Grinding disc first then a lil' burr work, flap disc, roloc sanding disc and finally roloc scotch Brite discs to finish them out. I also used a few of these other "wheels/discs" but I don't know the name of them...like a rough hard scotch brite. And before all that I drilled and tapped for all the new studs. Saskman, I used all the looms/dressings off the oe 307 that was in the truck. See pics of the rear looms. I had to drill and tap bolt holes for them also. I don't like how the 4 front wires are routed behind the motor mount. I would have to cut the wire or loosen the motor mount to get them back out. Hence the reason I didn't terminate them yet. This is a low mileage 400 from a box van that was used for storage and rotted into the ground. I had to drill and tap the block for the z bar ball stud. I did both holes aligned with a oe ball stud bracket so it's like every other sbc out there. Smoothed all the casting lines on the block heads and water pump. Slightly polished the distributor base. Port matched intake. Usually I would smooth out the edges on all the brackets but I had most of these painted up way before hand so I didnt. Here's a few more pics.
#3723 |
Here is a few more.
I had to replace the oil pan as it was pretty rusty. I used the oil dip stick from the van and cut it down some but kept it longer than the oe one so it's a easy reach in the 4x4 engine bay. I have the block set up for the idiot lite dash and for a set of autometers. Gotta find 2 more heat shields for the front plugs. The only breather I had that would fit the smaller valve cover gromit had a dent in the top. So in a way of paying homage to a 400 I added the cheesy caprice emblem too the dented breather ![]() I have a metal tube(on the air cleaner)that goes into the crossover in the intake next too the choke tube. I think the tube went to a valve at the outlet of the ps exhaust manifold witch I no longer have. So I'm not quite sure if I need it or not will my choke still work right if I plug the hole? The ups guy dropped off My 400ci flywheel this morning ![]() And this brush guard followed me home from cl last nite ![]() I couldn't find another like it on my Google search it could be home made but for the $25. I paid for it its good enough for me and it fits great and bolted rite up....more dirty work. Then on the way home we come across a gas powered ez go Golf cart we Offered 2 beans for it...they excepted and we loaded it up. My bud said let's come back with the trailer. Oh heal no its a hour drive to get here I'll make it fit NOW! Holey cow if I had pics of all the crap I've ever had loaded in this lil' truck...the piano and a skid of pavers were the worst.
#3724 |
Well, my truck woke up on the wrong side of the bed and ran crappy all day. Felt and sounded like it was running on maybe 6 cylinders or less. Exhaust smelled of less-than-fully-burnt gas.
So, when I got home from work, I started pulling things apart to see what was amiss. I noticed that the hose on the breather line from the air cleaner to the valve cover was separated from the steel elbow, so I pulled the cleaner off and then tried to pull the fitting out of the valve cover. It pulled the top half of the grommet off with it, so I had to pull the valve cover to fish the bottom pieces of the grommet out of the baffle. (I discovered in the process that I need new valve cover gaskets, but that's a project for another day.) I need to get a new grommet, obviously. Then I pulled the distributer cap off (HEI). The center contact is burned, and the 8 wire contacts are pretty nasty, too. The center contact and the rotating contact on the rotor are also in bad shape. PITButt getting the cap off so close to the firewall. So the next step is to buy a new cap and rotor. I don't know how much a coil is, but I think I might get one of those, too. These parts have bee there at least since 2003, maybe longer. I am hopeful that this will cure the problem, but, even if it doesn't, it needed to happen anyway.
'69 Longstep K-10: 327/SM465/T-221/Closed Knuckle Dana44/12-bolt. |
#3725 |
Midniteblues: THAT is a pretty Mouse!
