cargo lamp/ 3rd brake lamp combination
does any one make a cargo lamp thirdm brake lamp combination for the 67-72 Chevrolet pickups
thanks jim ellis |
Re: cargo lamp/ 3rd brake lamp combination
That would be great if someone did, but I've yet to find one. I converted mine to a third brake light, but now that you mention it, it would be very easy to create a combo. For the third brake light, I used the housing and put two Red LED lights in a fabricated mount. It works great, and is super bright. What you said got me thinkin. There is plenty of room in the housing to put one or even two clear LEDs in there and then wire it to the cargo lamp circuit. Then you get the combo you're wanting without changing the outward/stock lense. Awesome idea!
Dieselwrencher has done this mod using 1/4 size LED lights. I habe also copied his idea but haven't powered it up yet.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
![]() Join Date: Apr 2005
In
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
I used one from a 94-98 Silverado.... I had to reshape the mating surface with sand paper to make it fit the cab but it worked great.
This how i did mine. I hope to get it in this weekend
I stuck a super-bright LED module (several watts) in much as the fellow above. Here's a picture of the lamp, the module, and the results. It still works as a cargo light too of course.
1970 GMC Sierra Grande Custom Camper - Built, not Bought 1969 Pontiac 2+2 427/390 4-speed Coupe 1969 Pontiac 2+2 427/390 4-speed Convertible |
This how i did mine. I hope to get it in the weekend
