Old 05-16-2016, 11:56 PM   #51
1961apacheC10
Re: Lets see your gauge panel!
Custom made gauge panel and ash tray turned tachometer
1961apacheC10 is offline   Reply With Quote
Old 05-17-2016, 12:05 AM   #52
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
My current cluster; stainless sheet with the tach, Wideband, and Oil Pressure gauge. All other functions are run off the scangauge (which is just velcro'd in place, hence crooked)
I'll be adding 2 more guages and redoing the stainless with carbon.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 05-17-2016, 12:38 AM   #53
Grandpa54
Grandpa54's Avatar
Here mine
Grandpa54 is offline   Reply With Quote
Old 05-17-2016, 12:54 AM   #54
MusicMan70
MusicMan70's Avatar
Here's what we got for now.
MusicMan70
1961 GMC Suburban
MusicMan70 is offline   Reply With Quote
Old 05-17-2016, 10:46 AM   #55
Brandons63
Grandpa54 that's pretty
Brandons63 is offline   Reply With Quote
Old 05-17-2016, 02:32 PM   #56
Rust-O-Matic
Rust-O-Matic's Avatar
Just got mine put back together and snapped this pic last night.
Rust-O-Matic is offline   Reply With Quote
Old 05-18-2016, 12:00 PM   #57
dschmit
Grandpa54 what tach did you use? Thats cool being 6000 RPM!
dschmit is offline   Reply With Quote
Old 05-18-2016, 02:01 PM   #58
Grandpa54
Grandpa54's Avatar
Red line out of tn rebuilt the gauges for me and he supplied it. He will make your speedo 120 mph if you want it, mark
Old 05-19-2016, 12:40 PM   #59
Rust-O-Matic
Hey Grandpa54, what brand and type of paint did you use on the silver trim bezel? Yours is flatter and closer to the original sheen than mine is. The whole thing looks beautiful, by the way.
I have blasted and repainted mine twice now, using two different types of rattle can aluminum colored enamel, and I'm still not 100% happy with it. I don't mind the extra gloss on mine, but it takes 100 years to cure and seems pretty easy to discolor when handling it.
Old 05-19-2016, 02:12 PM   #60
Grandpa54
Grandpa54's Avatar
SORRY I DONT HAVE THAT INFO JOHN AT RED LINE DID THE RESTORATION
http://www.redlineg.com/redlineg/Welcome.html HERE YOU GO
Old 05-19-2016, 02:26 PM   #61
Rust-O-Matic
Oh, I see. Thanks anyway. Looks like he does nice work.
I decided to do mine myself. Apparently so I could continually obsess about all the minute details other people are never going to notice in the first place. Ha!
Old 05-20-2016, 12:23 AM   #62
Captainfab
60-66 Nut
Aluminum/silver paint needs a clear coat so that it does not smudge when touched and handled.
Old 05-20-2016, 07:48 AM   #63
corvettejim1968
corvettejim1968's Avatar
Hand Made Factory reproduction A/C vents
text or call 602-361-6421
Website for A/C vents
https://coolc10.com/
corvettejim1968 is offline   Reply With Quote
Old 05-20-2016, 08:25 AM   #64
Shaky
Six in a row makes it go...
Shaky's Avatar
Wow - a lot of variety and nice stuff in here!
67 C20 long step resto: http://67-72chevytrucks.com/vboard/s...d.php?t=342086
66 C10 long step build: http://67-72chevytrucks.com/vboard/s...=1#post3814790
CT to Alaska in a 67 C10: http://67-72chevytrucks.com/vboard/s...d.php?t=399224
“The height of sophistication is simplicity." - Clare Boothe Luce
Shaky is offline   Reply With Quote
Old 05-20-2016, 01:50 PM   #65
Rust-O-Matic
Thanks CaptainFab, I hadn't thought about that. I don't wanna hijack this thread, but do you have any idea if clear acrylic enamel can be sprayed over the (presumably) oil enamel I painted it with? The aluminum color was Krylon Rust Tough. The local oreillys didn't have any clear that wasn't acrylic. I'm gonna try a test piece first, but was curious if you or anyone else had any input. I have blasted and painted this damn bezel twice now, and I really don't wanna botch it again.
Old 05-20-2016, 01:53 PM   #66
corvettejim1968
I had mine powder coated. Just another option
Old 05-20-2016, 03:17 PM   #67
Rust-O-Matic
Yeah man, your powder coated bezel looks great.
If I had realized what a pain in the rear the "easy" route was going to be, I would have just got some real 2 part urethane and shot it like all my other parts, or had my buddy powder coat it. Unfortunately I let logic get in my way again. "It's just a trim bezel, surely a shot of rattle can aluminum should do the trick." It looks really nice in my humble opinion, but now I've already got a spot that needs a touch up, and guess I may as well clear it while I'm at it.
Old 05-20-2016, 10:32 PM   #68
Rust-O-Matic
For future reference, I tested 3 rattle can clears tonight over test pieces previously coated in the same Krylon aluminum color I used on my bezel, and none of them are acceptable. Duplicolor acrylic enamel clear, Rustoleum crystal clear enamel, and Krylon crystal clear all three turn the metallic silver to dull, splotchy gunmetal gray that looks terrible. Maybe this will help somebody in the future.
I'll stop cluttering up this thread with extraneous info and questions now. Thanks for putting up with me fellas.
Old 05-24-2016, 12:55 PM   #69
par4tom
I ended up going the Dakota Digital route...full electronic with programmable settings for tach, speedo and fuel sender ohms...
Fit right in and works great...turned out to be about $300 dollars cheaper than purchasing all the gauges seperately and there are ton of cool expansion options.
My Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=705185
How to Get Audiophile Sound in 60-66 Trucks
http://67-72chevytrucks.com/vboard/s...=1#post7236896
Building Your Own Speaker Kick Pods
http://http://67-72chevytrucks.com/vboard/showthread.php?t=730495
par4tom is offline   Reply With Quote
Old 12-03-2016, 12:08 PM   #70
harrison56
a little more done,
harrison56 is offline   Reply With Quote
Old 12-03-2016, 12:15 PM   #71
harrison56
I an't done yall, but I be comming on, slow!!
Old 12-20-2016, 02:49 PM   #72
oldies1938
Here's mine I'm using Dolphin gauges!
oldies1938 is offline   Reply With Quote
Old 12-20-2016, 04:28 PM   #73
forestb
forestb's Avatar
Here are my gauges installed
forestb is offline   Reply With Quote
Old 04-26-2017, 07:03 PM   #74
Northwest Outlaw
Northwest Outlaw's Avatar
previous owner had put the little gauges in already, so i figured painting it wasn't ruining anything
1961 Chevy Apache "BoomStick"
-First build, lots of plans, little experience. What's the worst that could happen?
http://67-72chevytrucks.com/vboard/s...d.php?t=694506
Northwest Outlaw is offline   Reply With Quote
Old 04-26-2017, 11:12 PM   #75
rvrfoot
Mine is under construction. i dont know what gauge too use yet.Name:  DSCN0730.jpg
rvrfoot is offline   Reply With Quote
