Old 03-09-2004, 10:07 PM   #1
stllookn
Saving 1 truck at a time!
stllookn's Avatar
12 Bolt Coversion from 6-lug to 5-lug
What years do the axles interchange or are there slight differences? What else needs to be changed...backing plates and brake assy or just hubs?
'68 C20 Longhorn 50th Anniversary 400/TH400
'68 C20 Longhorn 50th Anniversary 468/TH400w/buckets
'72 C20 Halfhorn (Longhorn w/o cab and front clip)
'69 Flxible Cruiser (look up ugly in the dictionary)
stllookn is offline   Reply With Quote
Old 03-09-2004, 10:23 PM   #2
Bowtie67
Bowtie67's Avatar
the 5 lug axles are longer, CPP sells a set of 5 log axles that bolt right in. I have seen some posts about guys making adapters to space out the difference so they could use the later axles..
Bowtie67 is offline   Reply With Quote
Old 03-09-2004, 11:45 PM   #3
Vince M
Vince M's Avatar
Another source for the axles are Early Classic Enterprises. ECE. Pretty simple. Take out the old axles and put the new ones in.
Others have redrilled the six lug axles for the five bolt pattern. That probably is the cheapest route to take.
68 Chevy CST SWB w/LS1, carb & 700r4. Golden Anniversary clone with a few improvements.
Vince M is offline   Reply With Quote
Old 03-10-2004, 12:39 AM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Looking at your signiture, this info probably will not help, but many of the 70 trucks had the wide axle under them, in which the 5 lug axles slide right in. No mods needed.
But on 69 and older, it is not a direct swap, and re-drilling would probably be the cheapest route.
Old 03-10-2004, 12:56 AM   #5
stllookn
stllookn's Avatar
Thanks guys, that helps quite a bit...how did you know that I am a minimalist at heart...LOL! Good thing my buddy owns a machine shop!
Old 03-10-2004, 01:42 AM   #6
23and56
From six to five
Just done it today.Switch 5 lug axles from71 truck to my 70 and they where a perfect match,in length and dia.Starting on front next to get disc brakes.
23and56 is offline   Reply With Quote
Old 03-10-2004, 10:47 AM   #7
HuggerCST
HuggerCST's Avatar
Did you have to change anything else except for the drums?
Wynne
70 CST short fleet Hugger orange & white, 350/350, ps, pb, air, tilt, tach/vac/speedwarning, original buckets, AM/FM, oak bed floor, shoulder belts, 3.5"/5.5" drop, 20" American Racing VN425s.
Build thread
53 Chevy shortbed
69 Camaro
Click here to subscribe
Chevy GMC International Truck Club Louisiana Charter Member
http://www.louisianaclassictruckclub.com
HuggerCST is offline   Reply With Quote
Old 03-10-2004, 11:14 AM   #8
boraxman
Keepin an eye out
boraxman's Avatar
Another thing to consider is, using later model (73-87) larger rear brakes. That would require backing plates, drums, pads and hardware off the later model truck. You can use the same e-brake cables.
1970 Chevy C10 SWB 5.3
1996 Toyota Tacoma SR5 4x4
2007 Vespa GTS 250 Scooter
ZIP 91351
boraxman is offline   Reply With Quote
Old 03-10-2004, 10:49 PM   #9
23and56
Besides the axles all I changed was the drums.I must correct myself as the parts came from a 71 chevy sububan.
Old 03-11-2004, 02:25 AM   #10
Longhorn Man
Well...5 lug wheels might make it easier to drive.
Old 03-11-2004, 09:14 AM   #11
Blue Beard
Blue Beard's Avatar
Make it go faster.....?
1970 Chev CST
2003 Harley Fatboy
1975 Chevrolet Step Van
1956 Chev Bel Air
1977 Blazer 2WD For Sale $3000.00
1978 Blazer 2WD For Sale $7000.00
1978 Silverado
2005 Monte Carlo
Blue Beard is offline   Reply With Quote
Old 03-11-2004, 10:00 AM   #12
Huck
Huck's Avatar
Similar question with a twist---what about 4x4 axels? Can you swap out the 6 lug rear axel shafts with a 2x4 5 lug axel shaft--assuming they are 71-72 models? There by using a 4x4 axel on a 2x4 5 lug truck-----
Huck is offline   Reply With Quote
Old 03-11-2004, 04:38 PM   #13
Longhorn Man
I can't remember what happened, but the 4X4 did have a width deal on there's too...but I don't know what to what though.
