Old 05-16-2016, 09:02 PM   #1
chazdo2
1971 Chevy oil pan help
My oil pan gasket needs replacing. I cannot get the pan out. Do I need to raise the engine or loosen the tranny to separate? At a loss the cross member isn't low enough and the rear of the pan hits the flywheel.
chazdo2 is offline   Reply With Quote
Old 05-16-2016, 09:31 PM   #2
jimmq
jimmq's Avatar
Re: 1971 Chevy oil pan help
well if you have a 4wd the engine needs to come out.. Word of advise, if you are using the one piece gasket, check with felpro and get the correct PN for your pan. There are 2 gasket thicknesses for around the timing cover.. Lessen learned
jimmq is offline   Reply With Quote
Old 05-17-2016, 06:41 AM   #3
chazdo2
thank you very much!!!!!
Old 05-17-2016, 08:36 AM   #4
Andy4639
Old member
Andy4639's Avatar
Lightbulb Re: 1971 Chevy oil pan help
You have to jack the motor up enough to clear it. If it's a real 71 pan then the timing cover will need to be taken off to get the lip of the pan out from behind it.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 05-17-2016, 06:27 PM   #5
chazdo2
no its a 1990 something 350 at least the starter from my 1994 350 fit directly in it. How do I find out what year my motor is?
Old 05-17-2016, 06:38 PM   #6
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
By the suffix code located on the machined surface in front of the passenger side cylinder head. There will be a series of alpha-numerics stamped on that machined pad. Post them up.
Gary
'cuz chicks dig scars...
I would never rebuild a 305.
Old 05-17-2016, 07:58 PM   #7
tdangle
tdangle's Avatar
I did this job on my 70 a couple of months ago. What a pain! I had to take the front of the engine apart (water pump, harmonic balancer, timing chain cover etc) and then put a 2x4 between the frame and the motor mounts to raise the engine enough to get the pan out. I used the Felpro 1 piece gasket and rtv at the edges per the felpro instructions. I will say it fixed my oil leak. Nice and dry underneath now.
It might have been quicker and easier to just pull the engine, I just don't have the room to do it.
Terry
1970 Custom Camper/C20 , GM Crate 350/7004R, Dana 60, factory AC
tdangle is offline   Reply With Quote
