Old 05-19-2016, 12:17 AM   #1
Dagreat7
Spindle/Rotor issue
Hello everyone. New poster here. Been searching on here for a while now.
But i have a few questions. My mom bought a 1983 C10 a few months ago. And she gave up on working on it. I have taken over the project recently. I started to take rebuild the complete suspension.
Lowering the truck with a 2 1/2 front and 4 rear. She bought the drop kit from LMC. Not a big fan of lmc but not to bad for smaller things.
My issue is the new spindles came in with only a 4 inch axle shaft. The old spindles have a casting of K10. Makes me thing the truck might be a K10. The specs on the old Spindles are 41/2 inch axle shaft. 1 3/8 inch inner bearing size. Those are my 2 issues. The new spindles are 4 inch axle shaft, and only 1 1/4 inch inner bearing size. Rotors are 1 1/4 wide rotors and 11 3/4 inch length rotors. Outer bearing fits on both just fine tho.
What makes a C10 and a K10?
Changing rotors solve the problem? To a 1 1/4 inch inner bearing size? And a smaller rotor to fit the 4inch axle shaft? If thats the fix? What rotor is the one to use? Part # or link appreciated.
Thank You for ur help. Will keep in touch with the progress.
Dagreat7 is offline   Reply With Quote
Old 05-19-2016, 12:41 AM   #2
UKNOWME
UKNOWME's Avatar
Re: Spindle/Rotor issue
C is 2wd
K is 4wd
2018 Audi S5- wife's ride
1980 Chevy Scottsdale http://67-72chevytrucks.com/vboard/s...d.php?t=543511
1981 Chevy Silverado- in pieces
1964 Chevy c10
2017 Jeep Wrangler JKU
UKNOWME is offline   Reply With Quote
Old 05-19-2016, 12:43 AM   #3
UKNOWME
UKNOWME's Avatar
You have HD rotors and LD spindles if I'm reading your info correctly.
1964 Chevy c10
Old 05-19-2016, 01:41 AM   #4
Dagreat7
Thanks for the fast reply.
Even looking at local parts stores. Specs online. I dont see a rotor to fit a 4 inch spindle shaft. Stock rotors measure 4 1/2 deep. Theres a different year/model that will work with these drop spindles?
Old 05-19-2016, 09:13 AM   #5
UKNOWME
UKNOWME's Avatar
What brand spindle did they send you?
1964 Chevy c10
Old 05-19-2016, 12:54 PM   #6
J Knight
J Knight's Avatar
You must have ordered drop spindles for 1in rotors. You need drop spindles for 1 1/4in rotors or convert to 1in rotors, inner bearing, and calipers.
John
82 Chevy Silverado 350ci/TH350
J Knight is offline   Reply With Quote
