Old 05-20-2016, 05:47 PM   #1
JCMjr
1970 Chevy C10 shortbed
I recently began the project of restoring my fathers 1970 C10. I'm pulling the inline 6 original engine this weekend. Any ideas or suggestions will be greatly appreciated.
JCMjr is offline   Reply With Quote
Old 05-20-2016, 06:00 PM   #2
ole dollor
ole dollor's Avatar
Re: 1970 Chevy C10 shortbed
First welcome to the forum from West Texas , just undo all the wires connected to the motor , trans bolts x 6 , put a jack under the trans to hold it up while you pull the motor , battery cables ,all water hoses , motor mounts , exhaust pipe . pull the radiator ,pull the hood off . disconnect the gas pedal rod. clutch rods on the driver side if it has a clutch. get your host or cherry picker and chain to the motor front and back and try and keep it fairly level , pull it to the front and up as you go . try and get a friend to help, makes it a lot easier......Good Luck ...Don
ole dollor is offline   Reply With Quote
Old 05-20-2016, 06:07 PM   #3
JCMjr
Thanks Don... Will post pics of the progress as it comes along
Old 05-20-2016, 06:17 PM   #4
ole dollor
ole dollor's Avatar
man we love pic's , lots of pic's . keep us posted .
Old 05-20-2016, 07:36 PM   #5
flashed
Welcome ,Im in to see another one .
flashed is offline   Reply With Quote
Old 05-20-2016, 07:58 PM   #6
72 Super
72 Super's Avatar
Welcome to the board. What are the plans for your fathers truck?
Ray
72 Cheyenne Super (Purchased new by my parents in August of 71) Black and White
72 Super is offline   Reply With Quote
Old 05-20-2016, 08:01 PM   #7
Z10
Z10's Avatar
Welcome to the forum! My truck started out as a six, but no longer. Check out my build thread and others and I'm sure you'll get some great ideas.
1969 RS/SS Z10 Camaro Pace coupe
1972 GMC Short Step buildhttp://67-72chevytrucks.com/vboard/s...=1#post6356218
1979 Mazda RX7
1979 Pontiac Trans Am WS6 & 1979 Pontiac Trans Am 10th Anniversary
1999 Honda Valkyrie
2006 Corvette Z06
2010 BMW 650i
Z10 is offline   Reply With Quote
Old 05-20-2016, 08:30 PM   #8
35boulder
35boulder's Avatar
Welcome from another Texan. I'm in. Pics please! Good luck
35boulder is offline   Reply With Quote
Old 05-20-2016, 10:20 PM   #9
Acorn
Howdy from East Texas!
If your memory is anything like mine, I suggest;
1- take a ton of before and during pics.
2- make note or mark things like motor mount, hood hinge position
3- painters tape and sharpie to label EVERY wire etc.
4- small boxes or ziplock bags to separate and label EVERY bolt, bracket etc.
5- take your time!
6- if your not sure about anything, post it here. Plenty of good folks here that are more than willing to help! Good luck!
The bitterness of poor quality lingers long after the sweetness of a low price is forgotten.
Acorn is offline   Reply With Quote
Old 05-20-2016, 10:35 PM   #10
ChuckLee
And keep your hands clear of pinch zones. Man that hurts bad! Don't trust your hoist more than you should either.
ChuckLee is offline   Reply With Quote
