Old 03-10-2004, 12:48 AM   #1
jugernot
Life, Be In It.....
jugernot's Avatar
Thumbs up Got My New One Piece Drive Shaft
I ordered it from Denny's Drive Shaft, about $300.00. I will put it in tomorrow. Then Order some stainless brake lines.
jugernot is offline   Reply With Quote
Old 03-10-2004, 12:52 AM   #2
bad 71 chevy
bad 71 chevy's Avatar
looks good
71 Chevy C/10 lwb 350
5 speed nv3500
3.73 rear end
2.5" Front Drop and 4" in the back
Edelbrock perfomer rpm manifold
Edelbrock 600 cfm carb
Headmen headers
bad 71 chevy is offline   Reply With Quote
Old 03-10-2004, 01:34 AM   #3
guitarornothin
RUNN over AGAIN!!!
guitarornothin's Avatar
Nauice!!!!!!!!!!
67-72 TRUCKS ROCK
70 SWB shaved and a 72 front clip.and a poly tank.
Peep mirrors and a BIG BLOCK 468 in the making.
XNXNXNXNXNXNXNXNXNXNX
,/. EMAIL ME HERE!, Dont pm me please
guitarornothin is offline   Reply With Quote
Old 03-10-2004, 01:43 AM   #4
angelsairman
Future Owner
angelsairman's Avatar
whats it going in?? Is it possible to convert a 2 piece driveshaft on a long bed 2wd to a one piece??
Its not the end result that counts most...its the journey along the way that's most rewarding
My truck doesn't leak, it just marks it's territory
angelsairman is offline   Reply With Quote
Old 03-10-2004, 01:43 AM   #5
stelth2002
Young Gun wth Fast Inline
stelth2002's Avatar
Long or short box, i want to do this to my truck also.
1967 Chevrolet LWB with built 292! 415 ft. lbs of torque, 4 speed :O with 27% overdrive too, 3.73 Posi. Frame and body done... getting painted!!!
stelth2002 is offline   Reply With Quote
Old 03-10-2004, 01:47 AM   #6
guitarornothin
RUNN over AGAIN!!!
I meant jugernot's AVATAR!!!!!!!!!!
67-72 TRUCKS ROCK
Old 03-10-2004, 01:49 AM   #7
jugernot
Life, Be In It.....
jugernot's Avatar
I am putting it in a 68 short step side. There is a maxium length for a one piece drive shaft, but I can't remember what it is. I think a one piece for a long bed is too long. I no expert though.
There is a pic of the truck.
Old 03-10-2004, 03:01 AM   #8
68LSS1
68LSS1's Avatar
Do they give a warranty or horsepower gaurantee (sp) ?
'68 Short Step
LS1/T56, Hydratech, Fatman Fabrications Stage III, Baer, Hot Rods to Hell, US Body, S&W, etc
68LSS1 is offline   Reply With Quote
Old 03-10-2004, 05:56 AM   #9
sixty8chev
The Sauz
sixty8chev's Avatar
Correct me if I'm wrong but don't four by's and 73 up long boxes have a single shaft out back, I don't think length is a problem.
68 lwb 2wd (spread between 3 garages)
72 Burb - Flat Deck
92 Yukon 3" lift - 33's - the new bush pig
01 Sierra - Daily Driver (for now)
sixty8chev is offline   Reply With Quote
Old 03-10-2004, 06:39 AM   #10
ACES
Life is a gamble
ACES's Avatar
looks nice and shiny
1970 Orange CST C-10 w/350, posi, Longbed
The torpid artist seeks inspiration at any cost, by virtue or by vice, by friend or by fiend, by prayer or by wine.
-- Ralph Waldo Emerson
ACES is offline   Reply With Quote
Old 03-10-2004, 08:10 AM   #11
HYPERMAN
shaft
That looks great. It is stainless I take it. What is the lengeth of it U-joint to u-joint? and what are you using for a tranny? Is your engine in the forward v8 position?
I need to make one. save me the measuring trouble.
Thanks,
Peter
HYPERMAN is offline   Reply With Quote
Old 03-10-2004, 12:22 PM   #12
imdarren
imdarren's Avatar
Sixty8,
My 72 Long Bed 4X4 has a one pc drive shaft too. Remember that a 4x4 has a transfer case, that ends up making the rear drive shaft shorter.
Washington State
1967 Chevy C10 LWB Rodstoration In Progress.
1972 K20 Cheyenne Super
imdarren is offline   Reply With Quote
Old 03-10-2004, 12:33 PM   #13
71'tahoe
71'tahoe's Avatar
Guys,I think the reason for the two piece shaft was for the trailing arm trucks.I own two 85'chevy 4x4s and 1 2wd short bed 83' and they all have one piece shafts. I think youlll be alright going with a one piece shaft in your long bed truck. The only place to check is where the factory put the crossmember for the trailing arms, if you get to much wait on the back it might cause interfernce with the shaft and the cross member.Unless you have leave springs and the trailing arm crossmember is not in there. Then you should be ok
71'tahoe is offline   Reply With Quote
Old 03-10-2004, 12:42 PM   #14
Slammed67
Progress = 0%
Slammed67's Avatar
I would advise you to make your won measurements if you are having a driveshaft made. There are too many variables involved such as engine location, transmission type/length, rear ride height, etc.
Jason - '67 GMC swb | '57 Bel-Air 4dr hardtop | '56 210 4dr Wagon | 2000 GMC Sierra
Slammed67 is offline   Reply With Quote
Old 03-10-2004, 01:44 PM   #15
crazy4chevs
crazy4chevs's Avatar
is it aluminum or stainless? very nice, good price too.
70 chev c10 swb fleet
72 grill, sb 400, 2/4 drop.
68 chev c10 swb fleet
Early classic 4/6 drop with 4wheel disc brakes 9"rear 67-8 buckets tilt and A/C
Classic GM Truck Club of Washington
crazy4chevs is offline   Reply With Quote
Old 03-10-2004, 04:48 PM   #16
jugernot
Life, Be In It.....
jugernot's Avatar
HYPERMAN
It is aluminum, 55 inch long. I have a 327 .40 over, 350 tranny. Its rated for horse power well over what my 327 will be putting out.
Old 03-10-2004, 04:58 PM   #17
jugernot
Life, Be In It.....
jugernot's Avatar
I would agree with Slammed67, you should take measurements of you own. There are to many varibles. IE differential, tranny, etc. I will say the guys at Denny's Drive shaft are very professional and are happy to expalain this to someone who lack the knowledge, as I did.
http://www.dennysdriveshaft.com/index.html
Old 03-10-2004, 09:51 PM   #18
69sixpackbee
My '72 w/ leaf rear has a 2-piece shaft and I don't have trailing arms....So, now what is the reason for them? Balance? Rigidity?
69sixpackbee is offline   Reply With Quote
Old 03-10-2004, 10:51 PM   #19
bad 71 chevy
i have 1 pice in my lwb 71
5 speed nv3500
3.73 rear end
Headmen headers
Old 03-11-2004, 12:05 AM   #20
robertwb
my dad had a one piece in a LWB about 10-15 yrs ago-the shaft came from a ford truck and he got u-joints to adapt ford/chevy frrom napa -but at the stock ride height he had to cut the bottomout of the x member the DS goes through-I think with a lowered truck that wouldn't have been required-or the cut x member could be reinforced
1972 LWB 4x4
1970 LWB 2wd
1971 chevelle
1972 datsun PL-521/nissan
robertwb is offline   Reply With Quote
Old 03-11-2004, 02:20 AM   #21
71'tahoe
71'tahoe's Avatar
69 1/2six pack bee,
im not claiming to know every thing that chevrolet and gmc did i wasnt on the design team but your reply that balance and rigidty might be the answer. all i know is on the few 67-72 trucks ive worked on they had trailing arms and the two piece shaft carrier bearing was located at the same cross-member as the arms thats all! I aint on here to start problems just tring to help out
