05-14-2016, 11:03 AM | #1 |
k10 grinding noise
Well my truck is experiencing its first problem, I drive down the road and sometimes the right front makes a grinding sound, it only does it sometimes and if I slow down completely it goes away. I jacked up the wheel no play in the wheel bearing or balljoints and was professionally aligned to spec. Anybody have any clues to what it is?
Seems to be worse in the rain Doesn't do it all the time Can be felt in the steering wheel Braking doesn't seem to effect it
86 c30 crew cab dually 454/400 4/6 drop SOLD 1-8-11 1981 chevy K10 short Bed Scottsdale SOLD 10-26-2020 67 GMC Stepside Straight six/3 on the tree "The Peach" 2020 Silverado Double Cab LT Z71 5.3 8 speed Daily Driver K10 build http://67-72chevytrucks.com/vboard/s...d.php?t=671934 The Peach build http://67-72chevytrucks.com/vboard/s...d.php?t=733903 |
05-14-2016, 11:08 AM | #2 |
Re: k10 grinding noise
Could be a driveshaft universal joint. An easy fix.
1982 K10 SWB 1987 V20 - Sold - Doh! |
05-14-2016, 11:21 AM | #3 |
I'm assuming the front? The rear was shortened and rebuilt last November. The truck also had manual warn hubs, but are about 17 years old.
05-14-2016, 01:21 PM | #4 |
Spindle bearing, maybe ???
Current/past Chevy/GMC trucks: 1958 Chevy C-60; 1965 GMC C-50; 1965 Chevy C-10; 1971 Chevy K-10; 1973 Chevy K-20; 1976 GMC C-20; 1977 Chevy C-10 Suburban; 1980 Chevy K-10; 1989 Chevy K1500; 1991 GMC V1500 Suburban; 2016 Chevy K2500 HD Other vehicles: 1988 Jeep XJ; 2011 Toyota 4Runner |
05-14-2016, 03:25 PM | #5 |
I was tracking down a grinding sound for a couple weeks. Always heard it when turning then it would go away. Finally heard it with the Blazer parked on level ground looked all over and saw the sparks from the balancer hitting the front crossmember. Replied the motor mounts and no problems with the grinding noise after that.
05-15-2016, 05:56 AM | #6 |
take the hub off and check the wheel bearing. Checking for up/down play just by jacking it up and grabbing the tire doesn't always show a bad bearing. Sometimes the caliper holds the rotor tight enough that you cant feel anything bad. If you haven't been into the wheel bearings in the last year or two, I would certainly visually check them. I repack the front about every 8-10k miles. sometimes more if ive been in deep mud or water. usually have at least one side that needs replacement.
05-15-2016, 09:46 AM | #7 |
I repacked the front bearings a year ago when I first picked the truck up (the wheel bearings were loose). I will check them and report back here.
05-15-2016, 10:37 AM | #8 |
I had a similar problem a few years ago with my 82 . Turns out the manual locking hub on one side was not unlocking. My hubs were old as well, installed a new set of Warn hubs, and problem went away. Also repacked the front wheel bearings at the same time.
05-15-2016, 05:45 PM | #9 |
Once you go in that deep, you might as well pull off the six nuts that hold the spindle and replace the needle bearing that supports the outboard end of the axle.
05-15-2016, 06:56 PM | #10 |
replace the spindle needle bearing with a plastic bushing from Longfield or RCV ( I think that's the ones making them now), much better design
05-16-2016, 01:47 PM | #11 | |
I never had one go out except when I was in Alaska, where I had (I think) three of them fail in under two years The symptom was always an intermittent loud buzzing noise from one of the front wheels.
05-18-2016, 11:00 PM | #12 |
So I took the passenger side hub off and I think the seal is not very good, there was dirt and some moisture in there. I cleaned the hub the best I could and put some grease in there. I took apart the other side and it looked fine, but I cleaned and put some grease in there as well. The passenger side hub doesn't engage as well as the drivers side but it works.
I swapped the passenger hub with the drivers side to see if it transfers sides. I took it on the freeway and so far so good. Hopefully it is OK. Does anyone know if they sell the rubber o ring/seal for the warn hubs?
05-19-2016, 05:54 AM | #13 | |
05-19-2016, 07:44 PM | #14 |
Just took the lock hub out. Also while I was in there, I turned the axle shaft by hand and it sounded like it was grinding and was kinda difficult to turn. Which leads me to believe the spindle bearing is no good like mentioned before. I am going to order these bearings and replace.
05-20-2016, 11:57 AM | #15 | |
But it's a good idea to refresh all the bearings on both sides. These old trucks need a little love every few decades
05-20-2016, 07:45 PM | #16 |
I hope this fixes the problem, I need to use the truck to pull a trailer to help me move in 2 months...
05-20-2016, 08:08 PM | #17 |
If you need the spindle bearings in a hurry, NAPA normally stocks them.
Part number BK1 About 30 bucks per side. Comes with new seals, too.
"Off the grid and on the seven day weekend plan" "One person cannot know everything, but between all of us, there isn't much we don't know." |
05-20-2016, 08:41 PM | #18 |
I ordered ones from TIMKEN from summit, should be here Monday. I checked out oreillys (don't have a NAPA near me) and all they carried was the junk champion made in china bearings, no thanks.
05-20-2016, 10:30 PM | #19 |
I have had an 82' 4 x 4 for over 20 years. You really need to keep an eye on those front wheel bearings. Especially if you do any off-roading. Seems a wheel bearing always lets you down at the worst possible time/place. When you are putting it back together, watch out for a flat washer that has a little "pin" on it. If I recall, it fits into a small hole in the inner nut.
