Old 05-21-2016, 02:43 AM   #1
vics stuff
adapt old style valve covers to LS motor
Does anyone know where a guy can find adapters to bolt a early style chevy valve cover to a LS motor valve cover. I am looking to cover the coils with a old valve cover. Any leads.
Vic
vics stuff is offline   Reply With Quote
Old 05-21-2016, 07:38 AM   #2
dec010974
dec010974's Avatar
Re: adapt old style valve covers to LS motor
hello. if I remember correctly, I some the adapters on ebay.
dec010974 is offline   Reply With Quote
Old 05-21-2016, 07:45 AM   #3
dec010974
dec010974's Avatar
Is this what your looking for? Why would anyone want a LSx engine to look like a SBC? That's like saying, I want my hot wife to look like an ugly woman. I hope not to offend the ugly women out there.
Old 05-21-2016, 08:03 AM   #4
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: adapt old style valve covers to LS motor
My simple fix was installed some 1/4 x 20 small bolts in the coil brackets and mounted my motor cover should work for valve covers too I would think.
You can see the right side front bolt and lock nut in this picture I have one on the left back side also.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 05-21-2016, 12:11 PM   #5
vics stuff
Yes dec010974 Those are to replace the factory valve covers and remote locate the coils. I just do not have the room on the frame anywhere to remote the coils. looking to install a set on a LS motor that is in a 32 Ford coupe. Trying to stick with the 60's theme.
Does any one know where to buy a adapter. the adapter nests over the LS valve cover and allows the old style valve cover to cover the coils.
Vic
Old 05-21-2016, 03:25 PM   #6
mongocanfly
mongocanfly's Avatar
Check pic on post 29..robznob built some nice ones from bbc valve covers.http://67-72chevytrucks.com/vboard/s...=615179&page=2
Old 05-21-2016, 03:30 PM   #7
mongocanfly
I made these from some scrap alum sheet for mine..so you could fab you a set if needed
Old 05-21-2016, 05:50 PM   #8
Willie Makeit
Willie Makeit's Avatar
search on Bay for ICT Billet. they have what you need.
http://www.ebay.com/itm/LS-Valve-Cov...9WzhpW&vxp=mtr
Willie Makeit is offline   Reply With Quote
Old 05-22-2016, 02:05 AM   #9
vics stuff
Hey mongocanfly ! Those covers look great. I think that I will look into doing the same for mine.
Vic
Old 05-22-2016, 10:32 AM   #10
solidaxel
solidaxel's Avatar
Thanks, those were fifty $ less than the ones I found, just need gaskets!
Now for the PCV system!
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 05-22-2016, 12:19 PM   #11
vics stuff
Hey solidaxle Those will look cool on that motor ? My problem is I can not remote mount the coils anywhere in my engine conpartment , due to the fact that in my 32 Ford coupe there is no place to put the coils. So I had seen where a guy has just made some type of mounting brackets to accept the old style valve covers over the coils similar like mongocanfly but with small block chevy valve covers
Vic
Old 05-22-2016, 01:56 PM   #12
nsb29
nsb29's Avatar
put them inside on the firewall ??? I have seen big block covers some where but don't remember where though they look funky may be summit racing
nsb29 is offline   Reply With Quote
Old 05-22-2016, 04:28 PM   #13
jweb
jweb's Avatar
I think this is what you are looking for.
http://www.summitracing.com/parts/pr...MobileSwitchNo
jweb is offline   Reply With Quote
Old 05-22-2016, 06:29 PM   #14
vics stuff
jweb ! Have been in contact with summit and they do not have what I am looking for .
Will keep looking .
nsb29 had thought about remoteing the coils and with the size of under the dash there is not a lot of room for them.
Thank you guys for the suggestions
Vic
Old 05-22-2016, 06:55 PM   #15
clemsonteg
You could do the edelbrock coil covers. They look similar to BBC covers. Mine have had the Edelbrock logo shaved off
clemsonteg is offline   Reply With Quote
Old 05-23-2016, 08:36 AM   #16
nsb29
nsb29's Avatar
I knew I saw something sumwhere
Old 05-23-2016, 02:12 PM   #17
mongocanfly
On the edelbrock covers you have to use a certain coil from a car..the truck coils won't work..not sure which engine you have.I bought a set and they wouldn't work..so I just made my own.
Old 05-24-2016, 11:04 PM   #18
Advanced Design
Advanced Design's Avatar
Vic, another option is the Holley coil covers.
Also, depending on the look you are going for, Wegner Automotive in Wisconsin has a valve cover with coil cover combination. They can machine the top however you want...I think.
Solid, that cover looks good. Do you have a build thread going on the Corvette?
Advanced Design is offline   Reply With Quote
Old 05-25-2016, 01:13 AM   #19
clemsonteg
Good point. I didn't find that out until after I bought them from another member.
Old 05-25-2016, 06:16 PM   #20
jweb
jweb's Avatar
Here's another option
Amazon.com: TSP LS1/LS6 Fabricated Aluminum Coil... Amazon.com: TSP LS1/LS6 Fabricated Aluminum Coil...
I ordered a set of these, they were really nice but would hit my firewall. So they didn't work for me. If you have the space they're less expensive than the Edelbrocks.
Old 05-28-2016, 02:22 AM   #21
vics stuff
As mentioned that my LS motor is in a 1932 Ford coupe. The engine compartment is real small. That is why I am looking for a retro valve cover adapter to bolt directly to the top of the original LS cover.
Vic
Old 05-28-2016, 10:39 PM   #22
bpatrol
I used the ones from post 8
not sure if this is what you were asking about
bpatrol is offline   Reply With Quote
Old 05-28-2016, 11:49 PM   #23
Greenlee
Greenlee's Avatar
Wow. I like that look!
Greenlee is offline   Reply With Quote
Old 05-29-2016, 02:26 AM   #24
vics stuff
bpatrol , do those valve covers mount over the ignition coils. If so that is what I am looking for. I am not looking for the adapters that replace the LS valve covers.
Thanks for the help
Vic
Old 05-29-2016, 02:44 AM   #25
bpatrol
they do not mount over the ignition coils they replace the ls covers and you remote mount the coils. it really is the cleanest look on the cheap . especially if space is a concern.
if u are simply looking to cover the coils ,holley and edelbrock make a cover as well as ebay variants. but in my opinion they look out of proportion and big.
wegner and billet specialties make an all in one cover thats a work of art but it will be well over a grand .....for valve covers..good luck either way
phillip
